Discovered a display error
When I change volume automation, and look at the mix-window, I can see the fader do the move instantly, when it should. The display below the fader that shows the level in dB follows the fader movement with a very noticable delay.
There are even times, when this display doesn't show any change at all, even though the fader is moving. This is not a big deal, but I was very uneased when I just setup a fresh session to work with, and I couldn't see any change in that display. Always a creepy feeling, when things aren't how the should be, and you have no idea why. Can anybody confirm this behaviour?
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
Avids bad solder job discovered | cgold | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 03-05-2013 06:30 AM |
Insert i/o has to be the same, Discovered this?? | crizdee | Pro Tools TDM Systems (Mac) | 6 | 04-07-2005 01:32 AM |
ot - DISCOVERED - the King of ALL NERDS> | graveleye | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 04-14-2004 01:49 PM |
I Discovered This By Accident... | mattm | Pro Tools TDM Systems (Mac) | 10 | 01-05-2002 03:52 PM |
Autotune 3 TDM Bug discovered | Padley | Pro Tools TDM Systems (Mac) | 14 | 08-01-2001 10:32 AM |
