Re: Slate Trigger Midi Not Sample Accurate
That's great that that works. That implies that Battery is a plugin which has midi time stamping, which makes it sample accurate. Unfortunately, Trigger is not sample accurate with midi as it apparently does not have midi time stamping.
I assume you to be correct.
Slate wants me to send them a session anyway, perhaps this is something that they can fix in the future. At any rate, I'm ok with this "workaround" at this point. Thanks, Sig |
Any news/ solution to this issue?
Best, Sean Sean McDonald Red Medicine Recording LLC Sofa King Music Services http://www.seanmcdonald.com |
Nope, they never fixed it.
However, what I do now is put Battery 3 on an instrument track, use DTM or DRT to place all MIDI notes, send that output to an aux with Trigger on it and voila, works as expected. A bit of a workaround, and of course you need to use up more CPU by using a Sampler, but it works. Does anyone know of a SUPER bare bones sample playback plug that isn't Structure/Battery? EDIT - Looks like Izoptope iDrum or the upcoming Massey DRT w/ sample player would be good. I'm gonna demo iDrum and see how it works. I've actually used the "click" sound from DRT and exported it as a WAV sample that I use in the sample. Works great. |
I can confirm that iDrum is NOT sample accurate either. It's a neat little app, and we may keep it regardless of that fact, but it will not work in this manner.
We're back to using Battery 3 until Massey releases his new version of DRT. Thanks, Sig |
Can I use Strike's sample with Slate Trigger? | britune | Virtual Instruments | 4 | 08-22-2011 10:48 AM |
Slate Trigger sample explanation please! | Raoul23 | The Drum Room | 8 | 05-19-2011 08:13 AM |
Midi to trigger different sample? | digifriend | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 03-31-2009 11:07 PM |
Sample accurate midi? | Dopamine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-09-2005 11:48 PM |
Sample accurate MIDI playback | Siegfried Meier | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-27-2003 07:45 PM |
