Old 01-07-2019, 12:41 PM
danonbass danonbass is offline
Default Problem while using Reason as rewire in Pro Tools
I'm having two issues while using Reason as a rewire instrument in Pro Tools. I use Reason on an Aux Track and program inside of Reason instead of using an Instrument Track in Pro Tools to control instruments in Reason. I've been working this was for years with no issues. I have two things happening.
1. I get a consistent, short Midi Note played at C-2 being played. I can see the note on the midi input indicator on Reasons sequencer window. If I pull up an instrument I can hear it. And if I record it will be on the midi performance.
2. If I preview a loop in Reason I can hear it fine, but when I load it into a Rex Player the sound changes. It's hard to describe, but it kind of sounds like it's going through a Lo-fi effect. I've checked the obvious things that might cause this, but nothing is out of the ordinary.
Both these issues only happen when Reason is rewired in Pro Tools. Reason stand alone and rewired in Logic work normally. I thought it might be a compatibility issue with PT11, but I upgraded my system and it's still happening.
PT 2018.12
Reason 10.2.2
OS 10.10.5
Old 01-15-2019, 09:17 AM
Default Re: Problem while using Reason as rewire in Pro Tools
Trashing the System Preferences Folder cleared up the issue.
pro tools rewire reason 5 problem deziarlleh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-04-2011 06:08 AM
Reason 5 in Pro tools LE 8.0.3 rewire problem. LizS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 10-28-2010 04:18 PM
Problem with Pro Tools as Rewire Host for Reason 4 midi sordino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-28-2007 03:56 PM
instaled pro tools 7.3 & reason 3, REWIRE PROBLEM! tomward Pro Tools M-Powered (Mac) 1 03-04-2007 05:31 PM
reason - rewire - pro tools only 2 tracks problem Tex Tiles 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-11-2003 02:25 PM
