Basic Windows7 Optimizations/Interference
Perfect newbie question:
Will the basic system optimizations they go over in the Avid Youtube page interfere with other things I may use my pc for, other than ProTools? I'm basically using that PC for ProTools, but I also use it for recording some streaming video football games as well, and some web usage for protools how-to's. optimizations I'm referring to include: power management performance options disable startup items disc compression and indexing and desktop composition I'm as green as it gets, I don't want to change something if I shouldn't. Thank you! |
Re: Basic Windows7 Optimizations/Interference
I would avoid using the internet on the recording rig, also It might be a good idea to turn off auto updates, just my 2 cents, I learned the hard way....
Gear> C8, 002, Trigger Finger, Kontrol 49, Apc 40 SW > Pt 8, Reason 5, Recycle 2.1, Ableton Live Suite 8.02 Plugs > All Registered plug in's & Vinyl out the wazoo. Mp3 sucks |
+1 for turning OFF automatic updates. You should right-click on the Pro Tools icon and hit the Compatibility tab. Then check the boxes for the following items:
Always Run as Admin Disable Desktop Themes Disable Desktop Composition Also, since you are connecting to the internet, and will be a target for all sorts of bad stuff, get Acronis True Image(or similar) and save a drive image of your C: drive as soon as you have it working well. You will need that so you can restore from a virus/malware/Trojan attack(which will happen sooner or later) Some antivirus programs will sap your system resources and should not be used with Pro Tools. You do NOT want disk compression. Power management settings should be for drives to never sleep, monitor to never sleep, no screen saver. Open the pdf manual as I think all the tweaks are explained in there
Cool. Thank you very much guys, I appreciate it.
Albee, please clarify: save the drive image as soon as I have what working well? ProTools with the optimizations? Or the Acronis Imager? Sorry, I'm not too hip with computers. Thank you.
My recommendation of 3 images is as follows: Image #1, an image of Windows only with all tweaks gives you a clean baseline from which to rebuild. Restoring takes way less time than doing a fresh Windows install and repeating all the tweaks. Image #2(Windows and Pro Tools only) is handy if you install some 3rd party software that hoses your system(had it happen). Image #3 will restore to your complete setup so if you have a crash or an update that goes bad, you can restore way faster than starting from nothing. This can be a life saver if you get a virus, if the drive fails completely or if you update and regret it(like I did when 9.0.6 sucked, so I restored from my 9.0.3 drive image) Remember there are 2 kinds of computer user; those that HAVE had a drive crash, and those that WILL have a drive crash
Wow. Thank you Albee, that was the most thorough AND informative response one could receive. Thank you, most thoroughly. ....perhaps I should hire you as a consultant...
If only you could afford me oh wait.....I do this for free
Further optimizations for PC. | shimmyshimmy | Windows | 1 | 09-30-2011 05:40 AM |
Windows 7 optimizations | GtrDude | Pro Tools TDM Systems (Win) | 2 | 04-10-2011 10:50 AM |
Mac OS X Optimizations HELP ! | ley | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-26-2007 12:57 PM |
Optimizations for 6.1? | basschair | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-20-2003 09:55 AM |
XP optimizations for PTLE 5.3.1 | eon sol | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-19-2002 12:46 AM |
