Old 05-23-2006, 03:21 AM
Mac88s Mac88s is offline
Default Midi Setup Problem
I'm using PT 6.9 with the 002 and a Command 8. When I'm routing midi, I'm going out of my controller in to the C8, out of the C8 in to a midi patchbay, from the PB to sound modules. I've done this before with other systems, platforms, software, etc. with no problem. My problem here is that when I use the same receive channel on each module, they both play their preset assigned to that channel. Yet in PT I'm using the receive in the mix window as the receiving module. If I'm transmitting on "all" and rec on any particular module ch, only that module should play like virtual instruments do. In other software it's like assigning ports. Port 1 goes to Roland mod, Port 2 goes to Yamaha mod, etc. Same as in PT where you assign midi rec channel. The difference is no matter how many external modules I use and assign them on the rec ch in PT, they all play at the same time if sharing a channel, not individually. I actually need this many channels and instruments for orchestartion in case you are wondering. Thanks for the help!
PTLE 8.05
XP
SP3
P4 3.06
2GB RAM
002R
C8
Intel i865G
VIA OHCI 1394 Firewire
Radeon 7000
Old 05-23-2006, 04:23 AM
Default Re: Midi Setup Problem
Mac88s
When you select from the MIDI I/O Selector, can you assign your external modules and channels? If not try: Setup>MIDI>MIDI Studio
Hopefully this is not a 7.x only feature, but still, you should still be able to, in the Setup menus.
filosofem
Aaron Mulqueen - 001 HD Native
Old 05-23-2006, 05:47 AM
spkguitar's Avatar
I answered this over in the MIDI thread. Please stop cross posting.
PT 9 setup problem..Where are the MIDI IN options in setup menu?? Blickerding Windows 0 04-06-2011 03:44 PM
Midi Studio Setup - Big Problem - XP Digitalkidd MIDI 1 03-19-2007 11:03 PM
Midi Setup Problem Mac88s MIDI 7 05-27-2006 10:18 PM
midi setup problem. ianrush15 MIDI 2 02-09-2006 02:38 PM
Audio Midi Setup Problem Muzoid MIDI 1 09-26-2005 12:26 PM
