What\'s the Difference?
I am still new to PTLE, and I understand using different sample rates and bit depths, but when creating a new song in 6.9 why would I want to use +6 dB fader gain when I could use +12 ?
Re: What\'s the Difference?
the +6 is more backward compatible than +12.
and also when mixing you shouldn't need to ever turn the fader up that high, unless you tracked too low, but that means you should be fixing ur tracking techniques and if you have ur fader's set for +6 and need more gain than that you can put a compressor on the track and turn the threshold up all the way and ratio down so that it does not compress the signal then you can just use the output gain. that being said. For some reason i also use the +12 fader's even though i never need them.
www.klarityrecordingstudios.com |
What's the difference? | williamsoncj | General Discussion | 3 | 08-16-2010 01:45 AM |
what's the difference between 5.3.1. and 6.4 | king of the south | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-12-2005 02:09 AM |
difference between -10 and +4 | stickytapenrust | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-22-2003 08:22 PM |
No difference between 44.1 and 48k on the 001 | Park Seward | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 119 | 02-22-2002 10:27 AM |
L2 - big difference! | JACEK GAWLOWSKI | Pro Tools TDM Systems (Mac) | 1 | 01-22-2001 11:53 PM |
