Old 11-25-2008, 01:27 PM
cksbcville cksbcville is offline
Default "sticky" Markers? Any ideas?
I have audio from a presentation, I need to edit the audio taking out some long pauses inaudible questions etc. However, I have all the powerpoint slide changes written down based on the time code during the recording, so if I go cut out audio in shuffle mode the notes will no longer be accurate.
Is there any way to put in a marker that stays with the audio rather than time? So that as I edit the marker moves with the audio rather than locking onto the time? I tried it with markers set to bars|beats and absolute and no luck.
Not sure if the markers can do this or if anyone has another suggestion.
working on windows xp with PTLE 7.3.1
Old 11-25-2008, 01:58 PM
daeron80 daeron80 is offline
Default Re: "sticky" Markers? Any ideas?
You just have to make sure you select the marker track along with the audio track each time you delete in Shuffle. It would be kinda cool if there were a pref for "Markers follows Edit" like there is for "Automation Follows Edit." But there ain't.
David J. Finnamore
Nyquist was right.
PT 2021.6 Ultimate | Omni | macOS Catalina in a Trashcan 32GB
PT 2021.6 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 11-25-2008, 02:11 PM
Possible alternative tack - haven't tried this but it should work.
1. Cut it up in Slip mode (leaving everything where it is - tried the Strip Silence tool, BTW?) so that each marker would fall in a separate region.
2. Make a Sync Point in each region where you would have put a marker.
3. Rename the regions in such a way that they'll be contiguous in the Regions bin.
4. Remove them from the track (Select All, Clear), drag them back in using Timeline Drop Order: Left to Right (bottom of Regions bin menu). This step assumes there's no automation on the track yet - if there is it would erase it unless you uncheck Automation Follows Edit.
Now you have a sync point at each place you would have put a marker, and if you do further editing, the sync points will move with. There are certain operations that remove Sync points, so you'd need to keep an eye on them.
David J. Finnamore
Nyquist was right.
Old 11-25-2008, 02:14 PM
I can select either the marker track or the audio track but not both at the same time.. also when I select some of the marker track and hit delete... it just clears any markers in that area.. it doesnt seem to move the marker track? I am sure this is a simple pref or something - but any suggestions on linking those two?
Old 11-25-2008, 02:43 PM
Hmm. I have the same version and I don't have any trouble selecting Marker and audio track together (shift-click to select the other track). You're right, the markers don't move in Shuffle if only the Marker track is selected - not sure why; always bugged me. But they do if you select on an audio track at the same time. Obviously, if you delete in the Marker track, any markers selected are going to be deleted. Presumably, if you're only deleting dead space, no markers would be included.
BUT - thought of an even better plan on the drive home. Use the Color Palette to color the audio differently from marker to marker (separating the file into additional regions at the markers as needed). Then edit away, and when you're done, make a new marker at each color boundary. Fall off a log simple. Combined with the Grid = Regions/Markers mode, it would go really quick.
David J. Finnamore
Nyquist was right.
Old 11-25-2008, 02:53 PM
Thank you! Man I swear this Digi User conference (and the wonderful people -- blatant suck-up -- who populate it) have saved me a lot of hassle and headache - thanks again!
sticky "Firmware related errors and resolutions for HD|Native Hardware" doesn't wo basicbass Pro Tools HDX & HD Native Systems (Win) 1 04-03-2013 05:55 AM
"Sticky" for Correct Uninstall-Reinstall Process for Pro Tools! RokVox macOS 28 09-26-2012 01:01 PM
Make Audiosuite plugin "sticky" Meads Pro Tools 9 0 11-24-2010 07:40 PM
-6101/-9138 errors - "low on memory" - any ideas? edfreeze 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-05-2010 10:11 PM
What is this "bug sticky" thing? Postman Post - Surround - Video 20 12-09-2009 10:53 PM
