Annoying SSL G-Channel/ICON bug?
When I bypass the EQ section in the G-Channel all "In" buttons for each band come on on the console, and vice versa when I enable the EQ again. So, I hear all the EQ changes that I make, but the D-Command's EQ section tells me that all bands are disabled.
Anyone else?
Re: Annoying SSL G-Channel/ICON bug?
Of all the plugin and Icon bugs, that's the one that bothers you the most?
Yes, and obviously I haven't discovered many issues yet since I bring this one to the table. Which bothers you the most?
I see the same thing here and frankly never even noticed.
I actually think this is a "feature". I bet if you ask about it, they'll say that. Since on the real SSL you cannot bypass each band, Waves decided to make the "in" buttons serve as the EQ bypass. It goes against the UI of the D Command but otherwise how would you bypass just the eq?
Yeah, but it's counterintuitive. I get confused easily.
D-Control - Channel Display - Track Name Mode (ICON NOOB) | Ryan Young | ICON & C|24 | 2 | 07-28-2013 11:54 AM |
Can I lock a fader similar to ICON Focus Channel? | macaholic | Artist Series | 1 | 12-15-2010 12:13 AM |
Selecting a Channel on Icon does not select channel in ProTools | teacherman | ICON & C|24 | 2 | 06-07-2010 11:59 AM |
Another annoying issue. A good issue, but still annoying. Plugin latency. | DJ Hellfire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 25 | 05-20-2010 05:26 AM |
Annoying, annoying, annoying... error 2 | Anibal | Pro Tools TDM Systems (Mac) | 9 | 03-07-2003 02:20 PM |
