PT 6.9 track select bug
Well, maybe not a bug, but an anomoly...
In most windows (Mac) you can now select a range of tracks with the shift key, and then deselect individual tracks with the command key. However, in the "Import Session Data" window, you must deselect individual tracks with the "control" key. Seems like a stray PC command has made its way into the Mac environment. Anyone else feel this is counter-intuitive? Seems like the track select/deselect convention should be consistent for all windows. (bug report submitted) rcm
Save early and often! (or once a day whether you need to or not...) |
Re: PT 6.9 track select bug
Speaking of track select bugs, here's a small one. When you select a range of tracks in the Show/Hide list with the Marquee, if you over shoot and select too many tracks, you can't "back up" to un-select tracks. In the Regions list, it works like normal.
Mark Ettel C.A.S. |
Thanks for reporting these - we are able to reproduce these and will report them.
Actually, if you just click a track in the Import Session Data dialog, it will toggle between selected and unselected - no control needed. You can also select / unselect a range of tracks by holding down the mouse button and dragging across several tracks. It works a little differently that the Edit & Mix windows to facilitate making large selections. -Paul Vercellotti Digi Engineering
Cheers, Paul Vercellotti Avid Engineering |
MC Transport - Jog Track Select | PlugSlut | Artist Series | 7 | 03-29-2012 05:56 AM |
Select Next Track using Axiom 61? | Jeanpaul | MIDI | 5 | 09-25-2011 07:42 PM |
Is it possible to select a track without using the mouse? | park | Pro Tools TDM Systems (Mac) | 3 | 09-21-2010 12:11 PM |
"select next/previous track" "rec enable track" key command? | maufau | Pro Tools TDM Systems (Mac) | 6 | 04-22-2008 05:08 PM |
Is there a way to link track select and track focus? | uno1234 | ICON & C|24 | 13 | 02-14-2008 02:36 PM |
