Old 07-30-2009, 04:12 PM
Craiger Craiger is offline
Default What Did I Do? Play/Record has a pause ....
PT8 -
Open up a session and notice that I have to press the play button twice before it plays a session or records? And system seems to have a slight delay after you press play.
This happens if I press play/record using the mouse/transport, command8 or even the keyboard command.
I know it is something simple because I did it before.
Any suggestions ~
Old 07-30-2009, 04:20 PM
Premo Premo is offline
Default Re: What Did I Do? Play/Record has a pause ....
System specs?
Trash Prefs and databases can often fix that issue.
Update to the lastest cs update.
Lower the DAE Playback Buffer to level 1 or 2 in Playback Engine Window.
Old 07-30-2009, 04:21 PM
TCM's Avatar
TCM TCM is offline
Known issue:
http://duc.digidesign.com/showthread...ause%26quot%3B
002R BLA mod and Mbox mini 2, PT 11.3.2,
HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive
Old 07-30-2009, 05:27 PM
sunburst79 sunburst79 is offline
You might set the "open ended recording allocation" to 10 minutes in the prefs. This can speed response time up when pressing play.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 07-30-2009, 06:05 PM
Banana Banana is offline
Seems like they fired up a fix for 7.4 for the PPI, what about the 8.0? Should I change back to 7.4?
Old 07-30-2009, 06:27 PM
Fastermouse Fastermouse is offline
I still have the occasional PPI in 7.4cs9 but it seems to be when I have Velvet instantiated.
Old 07-30-2009, 07:06 PM
TOM@METRO's Avatar
If you follow the link given by TCM above, you will find that the search for this fix on our end has been pretty much exhausted, though there are some helpful hints. It's now is in the hands of Digi. They tell us they are working on it.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2021 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 08-01-2009, 06:38 PM
I have trashed the prefs and databases
I have set the "open ended recording allocation" to 10 minutes in the prefs
It does not matter if I have a plugin initated or not! With that said, all of my plugins are up to date except some that are VST wrapped.
Anymore suggestions? This is really embarassing and annoying!
Old 08-01-2009, 09:07 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
I take it u did NOT read all the replies on ur thread...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 08-01-2009, 09:26 PM
jeam25's Avatar
jeam25 jeam25 is offline
PT8 -
Any suggestions ~
Hi craiger !
Altogught is not my main software right now yesterday i passed by and saw the cs10 release so i downloaded it and like digi says they fix the PPI at least on 7.4 . On my PC worked so try it !!! OHhh yes you have to go back to 7.4 at least for the moment !
Just go to the digi plugins folder and make a backup of them if you want !! Then make a new install.. and now you can you 7.4 but with the 8.0 plugins.
I made it in the past and worked like a charm !!
Hey digi well done thats a BIGG start !
Hoping see the other things came up too so myself and others can came back to PT in full .
- Jesus Alvarado -
Keep the volume UP !
Trying to Get Around the PLAY/PAUSE Bug Kbiastre macOS 0 03-12-2012 02:26 PM
pause when play/record loubunk Windows 6 03-21-2011 02:59 PM
PT8-Goes into pause, not play original_min 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 34 01-14-2009 03:03 AM
Stuck in Pause - Can't play or record davegilliss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-15-2005 10:02 AM
Play and Pause Together? LeonD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-15-2004 10:55 AM
