Hi.
I have experienced the usual 9092 - 9094 error. I have read through a few posts here and noticed several things, but I am just an intermediate Pc user, so I am not certain in what concrete things I should do. One thing I have done is that I bought myself an external HD (7200rpm)(it has not arrived yet) that may be linked to the eSATA port. Does this work? Should I install PT on this drive or is it just important that I save on the external drive? Are there any other things I should do? I'm not sure whether my laptop is supported or not, but I think it should be good enough. Thank you. Svend SiSoftware Sandra System Host Name : NARROS User : Svend Workgroup : WORKGROUP Processor Model : Intel(R) Core(TM)2 Duo CPU P7350 @ 2.00GHz Speed : 2.00GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Mobile, Dual-Core Internal Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 3MB, ECC, Synchronous, ATC, 12-way, 64 byte line size, 2 threads sharing System System : Acer Aspire 5930 Platform Compliance : Intel Centrino Duo Mobile Technology Mainboard : Acer Eiger Bus(es) : ISA PCI PCIe IMB PCMCIA USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes System BIOS : Phoenix Technologies LTD V1.15 Total Memory : 3GB SO-DIMM Chipset Model : Acer PM45 Mobile Controller Hub Front Side Bus Speed : 4x 614MHz (2.46GHz) Total Memory : 3GB SO-DIMM Memory Bus Speed : 2x 768MHz (1.54GHz) Memory Module(s) Memory Module : Hyundai HYMP125S64CP8-Y5 2GB DDR2 SO-DIMM PC2-5300U DDR2-666 (5.0-5-5-15 3-20-5-3) Memory Module : Hyundai HYMP112S64CP6-Y5 1GB DDR2 SO-DIMM PC2-5300U DDR2-666 (5.0-5-5-15 3-20-5-3) Video System Adapter : NVIDIA GeForce 9600M GT (512MB DDR3, 275MHz/638MHz/2x300MHz, PCIe 2.00 x16, SM4.0) Storage Devices WDC WD3200BEVT-22ZCT0 320GB (SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) : 298GB (C:) (D:) TSSTcorp CDDVDW TS-L633A (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:) Disk : 638MB (H:) Disk : N/A (I:) Disk : 626MB (J:) Logical Storage Devices PQSERVICE : 10GB (FAT32) ACER (C:) : 143GB (NTFS) @ WDC WD3200BEVT-22ZCT0 320GB (SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) DATA (D:) : 143GB (NTFS) @ WDC WD3200BEVT-22ZCT0 320GB (SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) CD-ROM/DVD (E:) : N/A @ TSSTcorp CDDVDW TS-L633A (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Acer ICH9M LPC Interface Controller Audio Device : Acer (ICH9) HD Audio Controller Audio Codec : Realtek Semiconductor 888 High Definition Audio Audio Codec : Lucent/Agere Systems (Was: AT&T MicroElectronics) HDA softmodem Audio Codec : Nvidia 0006h Serial Port(s) : 1 Disk Controller : Acer (ICH9) Mobile SATA AHCI Controller USB Controller 1 : Acer (ICH9) USB Universal Host Controller USB Controller 2 : Acer (ICH9) USB Universal Host Controller USB Controller 3 : Acer (ICH9) USB Universal Host Controller USB Controller 4 : Acer (ICH9) USB2 Enhanced Host Controller USB Controller 5 : Acer (ICH9) USB Universal Host Controller USB Controller 6 : Acer (ICH9) USB Universal Host Controller USB Controller 7 : Acer (ICH9) USB Universal Host Controller USB Controller 8 : Acer (ICH9) USB2 Enhanced Host Controller System SMBus Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : Adobe PDF Converter (4000x4000, Colour) Network Services Network Adapter : Marvell Yukon 88E8071 PCI-E Gigabit Ethernet Controller Wireless Adapter 1 : Intel(R) WiFi Link 5100 AGN (802.11g (ERP), 54Mbps) Power Management Mains (AC) Line Status : Off-Line Battery No 1 : 61% Operating System(s) Windows System : Microsoft Windows Vista Home 6.00.6001 (Service Pack 1) Platform Compliance : x86 Windows Experience Index Current System : 5.0 |
I hate to be the bearer of bad news, but all Acer dual core laptops are incompatible:
http://www.digidesign.com/index.cfm?...4&itemid=28927 Not Supported — Known Incompatibility The Dell Precision M65 and M90 are Incompatible with Digidesign FireWire Peripherals Digidesign has confirmed that the O2Micro FireWire controller in the Dell Precision M65 will not recognize the 003, 003 Rack, Digi 002, Digi 002 Rack, or Mbox 2 Pro. On the Dell Precision M90 (which uses a RICOH FireWire controller), Pro Tools throws unresolvable 6088 errors when recording to a FireWire drive with the 003, 003 Rack, Digi 002, Digi 002 Rack, or Mbox 2 Pro connected. The Mbox 2, Mbox 2 Mini, Mbox 2 Micro, and original Mbox USB peripherals are unaffected, and are qualified for use with the Dell Precision M65 and M90. ACER Dual Core Laptops are Incompatible with Digidesign FireWire & USB Peripherals Incompatible with 003, 003 Rack, Digi 002, Digi 002 Rack, Mbox 2 Pro, Mbox 2, Mbox 2 Mini, Mbox 2 Micro, and Mbox ACER dual core laptops — all models |
Thank you for a quick answer.
That was bad news indeed. I'll have to build myself a desktop when I'm not so short on cash. ![]() thanks again. |
Depending on the age of the LapTop and where you bought it, you may be able to trade up/in to/for something else.
Derrkins GuyBarTola ******************** PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!! |
I wasn't able to. But thank you anyways.
![]() I will continue to ask questions here, so I won't make any thread pollution. ![]() I am looking at a desktop solution now, and I wonder if you guys think it will be compatible with my mbox 2 mini studio bundle. I am following the i7 thread, but it is a lot to read, and I could not find anyone who had tried this mb. I chose this rather strong package because I'm looking into upgrading my studio in the future when I know the basics. The desktop I am looking at now is something like this: INTEL MB BLKDX58SO 1600FSB CORE I7(FCPA-1366) DDR3 AUD+LAN RAID SATA ATX 10PK (BLKDX58SO) 2 X Sharkoon Silent Eagle 120x120x25mm 1000rpm 19 dB (silenteagle120x120-1000) Sharkoon Rebel 9 Economy Edition Midi ATX black, w/o PSU (tqxs02) INTEL Core i7 920 2.66GHz 8MB LGA1366 Boxed (BX80601920) Seagate 1TB 7200RPM S-ATA harddrive 3,5 *** (1TBSATA3.5) Seagate 1TB 7200RPM S-ATA harddrive 3,5 *** (1TBSATA3.5) G.SKILL 6GB DDR3 Kit (3x2GB) PC3 10666 1333MHz Non-ECC CL9 (F3-10666CL9T-6GBNQ) Chill Innovation CP-520A4M 520W Modular (CP-520A4M) PointOfView GeForce 9400GT 1024MB PCI-E Graphics Card (R-VGA150915-P) DVD±R/RW DL burner black (bulk), SATA (DVDRW_SATA_BLACK) I will probably go for win xp sp3. This package will cost me about 1.400$ If you can't imagine this is worth it, or if you can give me any better ideas I would be very thankful. SE |
Acer Aspire 5935G laptop with PTLE 7.3.1 or PTLE 7.4 | Hamdi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-22-2009 09:18 AM |
Acer Aspire anyone? | Aussie Scott | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-09-2006 09:09 PM |
ACER Aspire 3000 laptop..... | gdx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-02-2006 07:50 AM |
Acer Aspire 1800 and Pt 6.7 with Digi002R | kaineggs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-07-2005 05:12 PM |
Any hope for PTLE on my Acer Aspire 2001? | mdfried | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 05-24-2004 05:57 PM |
