Bounce to Disk Problems
Hi again,
Ok, Thanks to all of you (AND the manual & the other $35 Manual), I have figured alot out. I can now bounce to disk. Problem..... Bounces without a problem but when its done and saved as a .wav file nothing will open it. I tried to burn the song to disk and it gives errors. Tried playing it with WMP and it says its an unknown file format, but the properties says its a .wav. Any help will be great. You guys are the best here. Thanks again Jay
Digi 001 5.3.1 AMD 3.3 Ghz w/256 mb SDRam 250 + 60 + 80 Hard Drives |
Re: Bounce to Disk Problems
Be sure you are bouncing it as:
file type: wave resolution: 16 sample rate: 44100 If you already have the wav files, you can create a new session (call it "convert") and import all the wav files and re-bounce them with the settings as above. Then they should play fine.
- but the second mouse gets the cheese |
That was it!!!
It was set as Resolution 24. Changed it to 16 and Im all set! Thanks again Quote:
Bounce to disk problems ! | ley | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 04-21-2008 09:50 AM |
Bounce to disk problems | Punkbarn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-19-2007 11:53 PM |
Bounce to disk problems | Lugh98 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-25-2006 07:43 PM |
Bounce to disk problems | pinkdaygreenfloyd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 01-07-2006 08:42 AM |
bounce to disk problems! | SwedenPar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-14-2005 07:41 AM |
