Old 05-25-2023, 02:26 AM
alfiea alfiea is offline
Default ProTools not shutting down correctly
Hello,
I seem to be having issues with Protools Studio not allowing my Mac computer to shut down correctly. I've looked on the forums but see nothing of this issue.
I quit protools and the Mac will restart instead of shutting down, at which time I can then shut down. I am not sure what is causing this. Does anyone have any ideas?
I am using Protools 2023.3 with an apogee Duet 2 Mac OS Ventura / Mac Studio silicon.
thank you in advance for your help and suggestions.
Old 05-25-2023, 06:24 AM
its2loud its2loud is offline
Default Re: ProTools not shutting down correctly
Originally Posted by alfiea View Post
Hello,
You should make sure that Pro Tools is actually quitting and hasn’t just stopped responding as an application. There are known issues with Pro Tools not quitting properly.
If you’re trying to shutdown your computer before Pro Tools has actually quit, this may be the reason for the restart.
When quitting Pro Tools make sure it hasn’t stalled by opening the Force Quit window. OPT+CMD+ESC. You’ll probably need to force quit the application. Then you can shut down the computer.
Old 05-26-2023, 02:15 PM
thank you for your reply, much appreciated. I will try that.
Old 05-27-2023, 05:43 AM
Stephen Bond's Avatar
https://duc.avid.com/showthread.php?t=424735
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 05-30-2023, 01:46 AM
thank you Stephen. I am still having the issue but it seems to be a well known issue that I am sure will be resolved in time.
Old 05-30-2023, 03:02 AM
Yes indeed.
There are a few well-know issues which are not disastrous but have rumbled on over decades (such as EA problems, AAE/DAE errors etc). This is not a poke at Avid type comment as these problems are common to any manufacturing of a ecosystem. The best companies reward their employees generously and develop people assets to maturity as well as their products.
Stephen
Old 05-30-2023, 10:56 AM
Tweakhead Tweakhead is offline
excellent observation. worth repeating until it sinks in.
Old 06-03-2023, 06:53 AM
Talisker Talisker is offline
I have the same problem, but I found a workaround that seems to do it for me. Before I quit, I load up a very simple session and quit from there.
Mac Mini M1, 16 GB Ram, OSX 10.181.1,Focusrite Scarlett 18i20,Behringer ADA 8200,Pro Tools 2022 2xGlyph hard drive 750GB
Old 06-03-2023, 12:07 PM
climber climber is online now
hmmm... wouldn't this suggest, to you, that there is likely something in your session that is causing the issue? perhaps it might be worth making a copy of the session and start eliminating things, perhaps starting with your plugins.
just a thought...
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Old 06-03-2023, 12:22 PM
Ben Jenssen's Avatar
Sounds logical for me, and the slightly annoying problems I've had w/PT the last couple of years.
My issues have been PT crashing on quit, and throwing a "AAE is running out of memory" error on playback. Both seemed to come after having open large-but-not-very-large sessions for a long time, sometimes days.
When you load a small session, PT/AAE clears the memory of earlier session, and I guess that fixes it. So, I'm thinking it's a memory management problem.
Luckily, I haven't seen the two issues after upgrading to M2, Ventura, and PT23.3. But I haven't been pushing it much.
Problem Shutting Down ProTools LE ecovindaloo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-30-2009 11:33 AM
protools soundly shutting down elad_kl Pro Tools M-Powered (Mac) 1 10-09-2008 07:10 AM
ProTools keeps shutting down muman Pro Tools TDM Systems (Mac) 5 07-11-2006 12:46 AM
protools keeps shutting down langdonfarm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-09-2005 01:12 AM
Protools Shutting Down - Help!!!! komodo Pro Tools TDM Systems (Mac) 1 06-06-2001 06:52 AM
