Old 07-14-2008, 01:20 PM
manticore manticore is offline
Default Can i get Gain, HPF and +48 to follow when i change patch?
Hi
My first post.
Is it possible to change the input patch in a show and stil get the same gain/HPF value and +48 on/off to follow my input strips in any way?
There must be a faster way than saving all input channels one by one and paste them after i done my patch!?
Best
Mathias
Old 07-14-2008, 02:56 PM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Default Re: Can i get Gain, HPF and +48 to follow when i change patc
Hi Mathias,
The fastest way to do this is to copy the channel first, change the patch, and then paste the settings back. That will give all of the PRE settings you mention. By default copy & paste are assigned to function switches 3 and 4 respectively, or you can right-click on screen and choose copy/paste.
Sheldon
Old 07-15-2008, 12:38 AM
ok
So thats the only way. I think its faster to take a pice of paper and write it down(its 80 chn i need to patch)
Anyway thanks för fast anawers
Mathias
Old 07-15-2008, 09:08 AM
Hi Mathias,
I think we may be talking about two different approaches. If I'm understanding correctly, the approach you describe involves creating a preset for each channel, then applying these presets after the patch is made. The approach I describe uses the basic copy/paste functions - not channel presets - which should be much faster than using channel presets. It's certainly a lot fewer mouse clicks.
Here's an example, to help clarify:
1) Select the channel of interest
2) Press the F3 Function switch (assuming it's still assigned to the default Copy function)
3) Go to the patchbay and change the patch to the new input source. PRE settings will change to match that source.
4) With the channel still selected, press the F4 Function switch (assuming it's still assigned to the default Paste function). PRE settings will revert back to their original values.
Function switch assignments are set on the Events tab of the Options page.
Sheldon
Old 07-15-2008, 02:25 PM
thanks for all your tips!
i did my patch today, wrote everything down and then did all my patches and then changed all my gains etc by looking in my notes.
It would have been nice to have a feature that asked me if i wanted gain,HPF and +48 to follow my channel strip when i change my softpatch, mybe it´s just me but i often have to change my patch between music rehersal and productin rehersel because artists always tend to make alot of changes and adding instruments during rehersal....
I still love the Venue familly!
Best
Mathias
Old 07-23-2008, 02:43 PM
bmadix bmadix is offline
Default
Best
Mathias
My experience with an "evolving" input list at rehearsals (and we had plenty of "evolution!") was that it was easier not to change the patch, but just add the new inputs further down the line and simply move the channel strips on the desk to where I wanted them. It's simple enough to figure out where the inputs are in the patch later by pressing the "source" button. Otherwise, I'd advocate Sheldon's approach.
Old 07-23-2008, 08:06 PM
Default
Hi everyone,
Here's another method that works really well and allows you to reset the PRE settings for all channels in one go, compared to the cut/paste method I described earlier.
First, some background...
Every time a snapshot is stored on a VENUE system all of the console data (except plug-in settings) is captured and stored. We'll use this fact to our advantage in a cross-patch situation.
Here's how:
1) Before making the cross patch create a new snapshot to capture the current gain settings. Name the snapshot "PRE Settings."
2) Cross-patch all channels as needed. This will cause the PRE settings to change to whatever the newly patched input is set to. Do not panic...
3) Set the scope of the Pre Settings snapshot so that all input channels are scoped (red), and ONLY the PRE data type button is scoped. (This indicates that only the PRE settings for the scoped channel will be recalled - exactly what we want). Make sure the IN data type is NOT scoped (it should be gray).
4) On the Options > Snapshots page, under the PRE heading make sure all choices are checked (Gain, 48V, HPF, etc.).
5) Recall the "PRE Settings" snapshot. Result: the new patching remains in place, but you now have all of the original preamp settings back.
What's cool about this approach is that you can get the preamp settings back even long after making the cross-patch. So long as you haven't overwritten the snapshot with the new pre settings they can always be recovered using the steps described above. Even cooler, all of this can be done offline using the standalone software, in advance of the gig.
Don't forget to return to the Options > Snapshots page and set the PRE options back to their previous settings.
Also, if you have the IN data type (for input patching) scoped in any snapshot you'll need to update those snapshots to reflect the new patching. Otherwise you could be in for a surprise when the input patch changes mid-show...
Note the slight modification from what was previously written. The key to this approach is to use a recent snapshot that has the correct gain settings stored. If you've made any gain changes but not stored them to a snapshot in a while, it's best to simply create and use a new snapshot with the current settings rather than duplicate a previous snapshot.
Sheldon
Old 07-23-2008, 08:14 PM
Default
Originally Posted by Sheldon Radford View Post
Hi everyone,
Here's how:
1) Cross-patch all channels as needed. This will cause the PRE settings to change to whatever the newly patched input was set to. Do not panic...
2) On the Snapshots page, create a duplicate of the most recently stored snapshot. Rename it "PRE Settings."
3) Set the scope of this snapshot so that all input channels are scoped (red), and ONLY the PRE data type button is scoped. (This indicates that only the PRE settings for the scoped channel will be recalled - exactly what we want). MAkre sure the IN data type is NOT scoped (it should be gray).
4) On the Options > Snapshots page, under the PRE heading make sure all choices are checked (Gain, 48V, etc.).
5) Recall the snapshot "PRE Settings" snapshot. Result: the new patching remains in place, but you now have all of the original preamp settings back.
Also, if you have the IN data type (for input patching) scoped in any snpapshot you'll need to update those snapshots to reflect the new patching. Otherwise you could be in for a surprise when the input patch changes mid-show...
Sheldon
Sheldon,
Great tip... especially the "do not panic" part.
Brad
Old 07-23-2008, 08:28 PM
Default
Originally Posted by bmadix View Post
Sheldon,
Yep. There's nothing like staring at 96 channels and not recognizing a single gain setting....5 minutes to showtime.
Seriously though folks, take a few minutes to walk through this process using a show file you're very familiar with. It powerful stuff, but with power comes responsibility.
Sheldon
When editing clip gain lines video should follow Ale Post - Surround - Video 0 03-12-2013 11:02 AM
Clip Gain doesn't follow trim edits bug? JR Fountain Post - Surround - Video 0 02-17-2012 07:28 AM
How do I get the expression pedal to follow in patch canges (ground control pro) magie78 Eleven Rack 2 11-27-2011 11:38 AM
Clip Gain Needs To Follow Groups DougBull Pro Tools 10 3 11-18-2011 04:46 AM
Pro Tools does not follow MIDI (MIDNAM) patch names & banks Justin Kagan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-10-2007 05:40 PM
