Why the Delay When Recording at 1024 Samples?
Horrible. When I go lower to 512 or 256 I cannot record as the entire system stops and I get the dreaded -9094 error message. Looks like the only playback engine I can use for recording is 1024 but that's useless because of the delay. Help! PTLE6.9 P4 3.0GHz, 512MB Ram
Re: Why the Delay When Recording at 1024 Samples?
002r
Are you using a second, dedicated hard drive to record to? Is it internal or external? What type/interface ATA, SATA or USB, Firewire? Also, is it 7200 RPM? I once had a problem very similar with a USB external hard drive.
rockrev
End world poverty: ONE |
You could always go with the dreaded "Low Latency Compensation" option or whatever it's called under your Operations menu.
What type of pc are you using?
PT Ultimate 2020.3.0 1 HDX Card Lynx Aurora 16 (2) Windows 10 Pro 1909 ASUS X-99 II Intel i7 32GB RAM Gigabyte GeForce GTX 1050 Ti 4GB www.doylemusic.com |
http://rainrecording.com/products/element |
Something is definitely going on, but what I'm not sure. I would first make sure that everything jives with Digi's guidelines. Kill any service that isn't necessary (like Antivirus, etc.), follow all tested system tweaks (they're all over this site), and disable any open hardware ports (like USB) that aren't in use. Also, are you on SP1 or SP2? I'm still on SP1 and from all I've read, switching to SP2 is still asking for problems to come knocking.
rockrev
SP2 but everything's been fine up until now. I might have to bite the bullet and go pay for Digi tech support.
I have a friend who had this problem with a Dell computer. We spent weeks trying to figure it out trying everything. As a last resort, I changed the stock video card that came with the dell and lo and behold; problem solved.
What exactly do samples in Pro Tools mean? Like 128, 1024 etc. | rockguitarist1255 | Pro Tools 10 | 8 | 01-05-2013 05:43 AM |
Cannot change HW Buffer Size higher than 1024 Samples | shawnj | macOS | 1 | 02-25-2012 04:42 AM |
recording Stems Delay issue of around 4095 samples Grr | s0und80y | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 11-17-2010 05:41 PM |
System Delay by 3209 samples giving a 2 frame pre delay | tom.joyce | Post - Surround - Video | 8 | 05-17-2007 02:25 PM |
Davec: 24 or16bit? 128-1024 samples? | tapani | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-16-2005 03:40 PM |
