Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2020
Old 11-09-2020, 05:02 AM
Cayce Cayce is offline
Default Plugins Not Responding in Master Channel Strip
I'm trying to place some inserts in my Master channel—EQ, Compression, etc—but nothing I put in there shows any activity or response. For instance, the stock compressor shows nothing in the input meter when the signal comes through. When I place the same insert in my Sub Mix channel, it works as it should.
What am I missing?
Thanks.
iMac (Retina 5K, 27-inch, Late 2015)
4 GHz Intel Core i7
32 GB 1867 MHz DDR3
2TB Internal Fusion Drive
2 4TB External Drives with Mirrored Backups
2 External Monitors: 27" & 65"
Old 11-09-2020, 04:43 PM
Bookerv12 Bookerv12 is offline
Default Re: Plugins Not Responding in Master Channel Strip
What output pair is your master controlling?
bookerv12
Old 11-10-2020, 04:17 PM
If I'm understanding the question, my Master output is to 1 & 2.
4 GHz Intel Core i7
32 GB 1867 MHz DDR3
Mastering Plugins on Submaster or Master Channel in Pro Tool deanguidry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-18-2008 02:07 PM
Strip Faders not responding on 002 bighead314 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-21-2007 05:23 AM
Renaissance channel vs Channel Strip frenchman Tips & Tricks 1 09-20-2003 05:18 AM
Channel Strip on Stereo Master Fader stevemusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-15-2002 08:25 PM
Channel Strip and Master Fader fifty8th1 Tips & Tricks 5 06-07-2001 02:56 PM
