Are Passive Volume Controls Really No Good?
I was just getting ready to build a passive volume control for attenuation of the outputs of my Digi 192 interface. This simple solution would be perfect for me. However, on the Aloha-Audio DACTS stepped attenuator info page they state "We do not recommend passive preamps for studio environments, unless the lengths are under 1 meter and there are no digital transmission lines or computers in the room.)"
See: http://www.aloha-audio.com/dact-apps.html Is this true? Is anyone using balanced passive attenuators successfully? With what kind of a set-up. Any problems? Thanks, Scott
Mercy Sound Recording Studios NYC http://www.mercysound.com/ facebook.com/mercysound/ instagram.com/mercysoundstudios/ Next Generation Pro Tools-Realize the only plugins needing to be active are on the track you're currently editing & those affected by it...all others should be quickly, seamlessly and auto background rendered into audio. Now dust off your G5s. |
Re: Are Passive Volume Controls Really No Good?
If you splash out $ 500 and use a high quality balanced stepped attenutor you'll get the best sounding volume control for your ProTools with no hum probs period. No one has yet used this type of component in a passive volume control as far as I know. But with a $ 500 component the retail box would probably sport a price tag that would scare most people away. But that doesn't mean you can't do it yourself. It's only a five minute soldering and cigar box job anyway! [img]images/icons/smile.gif[/img]
This guy makes stepped attenuators, is very friendly and can help you: Phil Marchand <[email protected]> xoxo PV |
I use the Coleman M3PH with stepped, passive attenuator (the same one used in the SSL 9K).
Great box. coleman audio
iMac i7 2020 Monterey 16GB HD Native Thunderbolt |
I made one and it worked perfectly. I used one of the balanced stereo DACT attenuators. I also put it an enormous rack mount unit and milled a 4inch x 4inch aluminium control knob at my brothers factory. It is a very useful bit of gear and if a corporate client ever asks what it is you can tell them is the 'phasovelocoromitoratronorexiflexifier' and has no fewer than 78 russian military valves. They love that **** .
J |
http://www.nhthifi.com/pro_product.asp?subjectid=3
You can check out this Passive pot, I think it is around 150.00. I use one made by Niles it works great and it is unbalanced. I would recommend the NHT, being balanced. Mine works fine, I did have a -20db dim switch made so I could monitor at low level and listen with both speakers. The gain is so hot off the 2 buss that the -20 pad allows me to use the pot at a better resolution. I've found the same thing to be true with the Coleman if you are monitoring very quietly. The passive thing is great and my mixes became more sound over different speakers when I aced my Mackie years ago. Hope this helps |
Ask Nika about the nice self-built box he made..
-dave |
Good replies so far but is anyone using an three meter or greater cable from the passive attenuator to the speaker amplification?
I am also interested in building a passive volume box to replace my studio comm. The studio com uses a vca and everything sounds a little too smooth. Also it only quiets the signal down 70 Db, instead of infinity, the way it should be. But the passive project opens a new can of worms. My studio comm has a dim swich, mono switch, and a talkback mic that dims the control room volume. I dont want to give up these conveniences, in persuit of purer sound.
The danish audio connect pva looks great but what about the other pieces. I guess I want a ssl monitor section sitting on my arosy desk, not in a rack. I can't be the only one. |
I have the PVC box also. It's great. It's quiet, and it has a LOT of headroom. Both at input and output.
Volume Fade Controls Guitar Distortion.. Why? | tim_morell2011 | General Discussion | 5 | 12-19-2013 06:25 PM |
Pan controls are affecting Volume | Paul Marcellus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-02-2013 10:14 AM |
metronome (click track) volume controls | frcjt | Pro Tools SE and Essential (Mac) | 0 | 12-18-2011 07:47 AM |
MIDI volume controls | lacsong | MIDI | 3 | 05-01-2006 06:23 PM |
Volume Controls have stopped working... | hughes | Digidesign Hardware & Software | 6 | 05-31-2001 11:09 PM |
