Use naokontrol2 to record midi cc
Hi, I got a nanokontrol2 from Korg to allow me to record midi modulation and expression at the same time using the faders on it. The Nanoknotrol2 to is showing up as a midi devise and it's letting me press play, stop and record on it and its playing in and recording in protools. But this is not what I got the nanokontrol2 for because I can do this quicker with keyboard short cuts. So the nano is being recognised by protools. The problem is that protools is not recognising or allowing me to record midi cc data using the faders on the nano. I have set the first fader to 1 for mod and 11 on the 2nd fader to expression using the Korg Kontrol Editor. Pro tools is not recognising this. Im using the 2022.4 version of protools on a Mac 10.14 Mojave. Could you please help. Thanks, Dave
Re: Use naokontrol2 to record midi cc
Details of your Midi / Instrument track settings, screenshot if possible.
Do you have it set as a Midi Input Device? Not under Peripherals but in Setup>Midi? Set to correct channel, track armed, etc?
~Will |
Hi smurfyou, you're a genius. I though I had tried what you mentioned but obviously not because it's working now. I lost half a day trying to sort this out. So thanks a mill for the help
MIDI Record works but not Retrospective MIDI Record or MIDI Loop Record | cantfindabed | Pro Tools 2019 | 16 | 05-31-2020 02:22 PM |
How to record to Midi track - Overdubbing instead of destructive record? | awritersparadise | Pro Tools 9 | 3 | 05-07-2011 05:34 PM |
MIDI record enabled and found but wont record | BCRich | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-23-2010 12:51 PM |
Master Record button doesn't record arm MIDI tracks? | Borg | ICON & C|24 | 1 | 10-29-2007 07:39 AM |
Record MIDI track Then Record Again To Add Aditional Notes + | JCWarrior | Tips & Tricks | 5 | 04-13-2007 03:51 AM |
