Old 09-22-2012, 08:31 PM
DCGRIFFITH DCGRIFFITH is offline
Red face Pro tools 10 and Presonus 22 vsl
I am new to protools, I have a Macbook pro running Mountain Lion, a presonus 22vsl audio interface. The problem is that Pro tool doesn't recognize the Presonus in the i/o section. I am getting signal into the mac. When I check the "settings" "Sound" I get good signal. but when I add a track in protools and go to the I/O for the channel the interface doesn't show up. What do I do.
thanks for any help for this newbies
Old 09-22-2012, 08:32 PM
Jarizme4 Jarizme4 is offline
Default Re: Pro tools 10 and Presonus 22 vsl
I'm having the same issue! But with the Presonus FireStudio... :/ Inbox me if you get any help.
Old 09-22-2012, 08:55 PM
I will , I also have a m audio fast track and can't get that to work either
Hopefully we will get an answer, good luck
Old 09-24-2012, 10:39 AM
Check your Playback Engine. I just fixed mine.
Old 04-28-2013, 03:01 PM
bdjo bdjo is offline
I have the very same problem. I just bought Pro Tools 10.3.3, I have a presonus Audiobox 22vsl and Pro Tools won't recognize my audiobox on the setup hardware option.
Can you please tell how you fixed it ??
Old 04-28-2013, 04:02 PM
gtomassetti's Avatar
gtomassetti gtomassetti is offline
Assuming that your Presonus is installed correctly on your Mac, try this:
Launch Pro Tools, then immediately hold down the "N" key. If all goes well, you'll be able to select your Presonus as the playback engine, then off you go.
Good luck…
Mac Pro 6,1 ("Garbage can"), late 2013, 3 GHz 8-Core Intel Xeon E5; 64GB RAM; MH ULN-2 (Ethernet MHLink connection)
PT Ultimate 20.12.0; REAPER64; PreSonus Studio One 5 Pro, Central Station Plus, and FaderPort
McDSP All Access; Slate Digital All Access; Waves Diamond 12.0; NI Komplete; EW GhostWriter
Finale 26.3.1
Pro tools 10 and Presonus Studiolive 16.4.2 danwillmore Third Party Interfaces 13 08-11-2014 09:09 PM
Pro tools 11 and Presonus 16.0.2 firewire faynes Third Party Interfaces 3 12-05-2013 05:04 PM
Pro tools 10 with Presonus 1818vsl cakins macOS 2 01-25-2013 02:49 PM
Presonus AudioBox Usb and pro tools kharla macOS 0 01-19-2013 01:44 PM
Presonus FaderPort with Pro Tools. isaac12002cn Pro Tools M-Powered (Win) 13 07-17-2011 11:34 AM
