Selecting all the regions to th Right of the cursor
Can anyone tell me how to select from the cursor to the farthest right region on a track. If I press down arrow, everything from the cursor to the left (all the way to the beginning is selected. So, you would think that, if you pressed the up arrow, everything to the right of the cursor would be selected.......but no.
I did figure that if you Shift/Option/Return it will select everything to the very end of the session, but on many tracks, the regions do not go all the way to the end of the session. Thanks |
Re: Selecting all the regions to th Right of the cursor
Tou have to deselect -tab to transients- Then you can use -shift + tab-
dk
www.dpksound.com |
The down arrow marks the current timeline position as the start of a region and the up arrow marks it as the end of a region. To mark from the current timeline location push the down arrow... to extend the region to the end of the session.. press Shift+Option+Return (Option + Return takes you to the end of the session.. the shift modifier extends your selection).
How is this different than what you want? Rail
option-shift-return
Selecting a small portion of a track at the point of the cursor | RockStone007 | General Discussion | 2 | 01-14-2014 06:45 PM |
PT not selecting and highlighting Regions | Gothboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-18-2009 03:02 PM |
Selecting Unused Regions ... bug or no bug? | Don Geppert | Pro Tools TDM Systems (Mac) | 3 | 01-02-2007 07:34 AM |
Shortcut for selecting all regions | Dopamine | Tips & Tricks | 6 | 05-15-2005 08:19 PM |
selecting regions... | neonknight | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-05-2004 10:34 AM |
