ProTools 12 and Command 8
Is anyone using PT12 with a Command 8? I know it's not officially supported in PT11, but it still seems to work fine. Is this still the case with version PT12? Thanks |
Re: ProTools 12 and Command 8
Works as usual, far as I can tell.
Same here. No issues with 11 as well as 12.4.
js_nyc 15" Macbook Pro (Mid 2012) 2.3 GHz Intel Core i7 16G Memory PT 10.3.11/ 12.5.2 003 Rack OSX 10.8.5 ProToolsConsultant.com |
i sold mine years ago as Avid said it would not work .. maybe i should loo for another one .. always liked it ..
Working fine here Best budget controller they ever made. I don't use any of it's audio side, but as a moving fader controller for PT it's great.
You can still buy the faders (v.easy to replace with basic soldering skills i.e. you have to de solder the little wiring loom from the old fader and re solder it to the new one) The original PSU is a bit under specced and tends to fail, but as it's just a transformer in a box it's easy to make a replacement. And the best thing about it? Assignable plugin controls. You get to choose which plugin parameters are assigned to each knob/button. Priceless |
Mine works fine in MAC 10.10.5 and PT 12.4HD
Hey Everyone,
I just replaced my DM-3200 with a Command|8. I'm running 12HD Native. Do I set the C8 up as HUI?
Apple M1 Mac Studio (base model) ProTools Carbon w/SSL XLogic MADI-AX Instagram: https://www.instagram.com/sparkletune/ |
Thanks! I didn't know if there was a Command|8 driver that needed to be installed under PT12 (as it's not officially supported) or if it needed to work under HUI mode or something.
I appreciate the help. I'll let you all know how I make out!
I didn't load any driver, it's most likely inside the PT install
Command 8 with protools 11 | seabluemedia | Digidesign Hardware & Software | 2 | 02-06-2014 03:45 PM |
ProTools 11 and Command 8 - looks OK to me! | thumos | Pro Tools 11 | 1 | 09-12-2013 01:17 PM |
Protools 8 command 8 bug? | lesoufs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-29-2009 11:00 AM |
Need Command 8 for ProTools HD? | TBF Entertainment | ProControl, Control|24, Command|8 | 1 | 06-24-2006 09:18 AM |
command 8 and protools 5.X? | ariel keshet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-29-2004 02:40 PM |
