PT 11.1.2 Elastic Audio problem & crashes on quitting
Hi , i installed 11.1.2 and it has the same problems , the same Elastic Audio plug in problem , and it crashes when quitting (with projects) even when deactivating 3rd party plug ins.
Music keeps me alive |
Re: PT 11.1.2 Elastic Audio problem & crashes on quitting
Hi , I noticed something i would like to mention (you may see the attached image)
1.The iZotope dll file from the 11.1.2 installation doesn't have a digital signature, while the same file provided with the 11.0.2 Ea Fix solution has it. NOTE : Although i tried to fix this through Internet Explorer where you can check to enable running programs without digital signature , it's the same. 2.The iZotope dll file's size from 11.1.2 is four times larger than the 11.0.2 EA Fix (which works) how that can be ?? Please see the attached image for more clarification .
elastic audio crashes PT 10.3.8 / OSX 10.8.5 | Anibal | Pro Tools 10 | 9 | 04-01-2014 06:31 PM |
PT 10 HDX crashes every time Elastic Audio is used | conrad787 | Pro Tools HDX & HD Native Systems (Mac) | 4 | 01-22-2014 11:26 AM |
Protools 10.1 Crashes with Elastic Audio ? | jackp | Pro Tools TDM Systems (Mac) | 0 | 04-18-2012 12:07 PM |
Elastic Audio crashes PT | scottleader | Pro Tools TDM Systems (Mac) | 2 | 04-14-2009 10:32 AM |
PT often crashes when quitting | stoogee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 11-14-2006 10:31 AM |
