Old 03-12-2002, 11:42 AM
John McDaniel John McDaniel is offline
Default Multiple bit depths in one session - WHEN??
This is becoming more and more important.
Digidesign: when will we be able to use multiple bit depth files in a session (ie: 16 and 24 bit at the same sample rate) without "conversion." Padding 16 bit files with 8 empty bits is very cumbersome when bringing files into a session.
Additionally, in HD systems, will we need to pad 16 bit/48k source files out to 24 bit/96k in order to use them? Is it in the plans for PT to be able to do this without "conversion"? Not asking for SRC on the fly, just to have PT add the empty bits on the fly. I'm told other systems can handle this. It's important to people with huge libraries of SFX and other materials on hard drives.
regards, j mcd
Old 03-13-2002, 07:09 AM
DigiTechSupt's Avatar
Default Re: Multiple bit depths in one session - WHEN??
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by John McDaniel:
...in HD systems, will we need to pad 16 bit/48k source files out to 24 bit/96k in order to use them?<HR></BLOCKQUOTE>
-Yes, PTHD works in the same way that previous versions do...files of a different bit depth and/or sample rate will be converted when importing them into a session.
Brent
Avid Audio Tech Support
Support FAQ
Old 03-13-2002, 02:34 PM
Are there any plans to change this? It's a waste of time and HD space. 16 and 24 bit files of the same (or integer multple) sample rate NEED to be directly usable in a session.
This has been brought up here before with a number of people chiming in to agree.
j
Old 03-13-2002, 04:04 PM
F Umminger F Umminger is offline
Multiple bit depths could probably be supported, but different sample rates will always need to be converted. Converting sample rates, even by integer factors, is NOT just a matter of stuffing in zeroes.
Frederick Umminger
Digidesign Plugin Engineer
Old 03-13-2002, 06:03 PM
Rythym Stick Rythym Stick is offline
Frederick,
I think its quite clear that we are talking about bit depth.
Every other audio program does it and has done for ages.
You would think that DAE would have been upgraded for the HD release.
This is a bit slack.
Its a very important feature as we all work at 24 bit but use many samples at 16 bit from CDs.
This should be a GIVEN and not a "could be".
Breaking up multiple songs in one session into multiple sessions? rmandelbaum Windows 10 08-14-2013 10:05 PM
Multiple bit depths in same AAF/OMF colinato Post - Surround - Video 1 09-28-2010 08:33 AM
mixed bit depths matt connolly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-12-2004 05:21 PM
SSC Bit Depths nozza1 Digidesign Hardware & Software 0 06-15-2001 02:55 PM
Multiple bit depths in PT: WHEN?? John McDaniel Tips & Tricks 7 01-31-2001 09:29 AM
