Old 01-03-2020, 09:41 AM
pgripp pgripp is offline
Default Vintage mac setup for opening old PT sessions
I'd like to set up a mac system so that I can access my old sessions (SD2). I'm wondering if anyone has done this, and what is the recommended old stuff to get.
I'm thinking G4 iBook with protools 8 and MBOX2 Mini (usb stick thing).
Any suggestions or thoughts?
Old 01-03-2020, 10:02 AM
nedorama nedorama is offline
Default Re: Vintage mac setup for opening old PT sessions
I was in the same situation and bought a used MacMini that ran 10.7.5 and Pro Tools 10. no need for external devices, you can convert in the box. I only had 2GB RAM in mine, so had to delete extra fonts, etc. to get the smallest system possible. If you can get an old Mac with 4GB Ram, you should be fine. Search to see minimum requirements to run Pro Tools 10 as that's the last system to use SD2 files.
If all your SDII files are contiguous, just buy Audaptor - it's an app that converts SD2 files to WAV.
Regards,
Ned
Monkey Boy Studios
2019 16" MBP, 32GB, 1TB SSD; OSX 10.15.7; 4TB USB-C G-Tech External
Summit Audio 2BA-221, TLA-50 -->Focusrite 18i20 3rd Gen, Eleven Rack, Pro Tools 2021.3
Plugins, Virtual Instruments, and real ones
Old 01-03-2020, 10:05 AM
DetroitT's Avatar
DetroitT DetroitT is offline
A Pro Tools 10 system will convert then save .PTX sessions
Also a not so old computer can be utilized.
Old 01-03-2020, 11:14 AM
My Nashville studio kept an old G4 with an Mbox 2 and LE8 for this purpose
Old 01-03-2020, 11:18 AM
JFreak JFreak is online now
As said, PT8 or PT10 is just fine for what you want to do. However, if you need to open sessions older than .ptf format (PT7-9) then it might be more tricky.
Old 01-03-2020, 02:17 PM
Thank you all for the info and suggestions.
My dream setup would open sessions with the old pre-intel plugins. I'll post again when I figure something out.
Old 01-03-2020, 11:32 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
I found a reman g4 mirror door to replace my old G4 450 with PT 5.* for not too much cash. It had a junk hard drive in it but HDD's are so cheap these days and i didn't need a fast solid state so i just put a 1 TB 7200 in it and it works great for converting SDII to wav.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 01-04-2020, 07:07 AM
EGS's Avatar
EGS EGS is offline
My old Mac G4 still works for these conversions. It dual-boots to OS9/PT5 or OSX/PT6.
Click for audio/video demo
Click for resume
Old 01-06-2020, 09:27 AM
huzzam huzzam is offline
another option to having an extra machine would be to install snow leopard (or windows 7) in a virtual machine on your current studio computer, then install pro tools 10 in there.
the process of doing this is too much for me to go into in a post here, but google knows everything! but here's a site to show you what the process is like to see if you have the appetite for it. ignore the references to a windows host, the same process should work on mac...
http://www.macbreaker.com/2012/02/sn...irtualbox.html
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest
* Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1
* PT 23.6 + Ableton Suite 11.3
* Soundtoys + Valhalla + Fabfilter + Spitfire
* RME Fireface UCX II ~ Arturia Keylab Essential 49
* various clarinets, trumpets, flutes, plucky stringy thingies
Old 01-06-2020, 10:11 AM
That would not be legal, but if you have Snow Leopard installer disk then I would not see it very unlawful either
I/0 setup weirdness, sessions overwrite my setup digidesigner Pro Tools TDM Systems (Win) 0 10-20-2011 11:40 AM
Opening LE 7.1 Sessions on LE 6.x force76 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-22-2006 07:11 PM
5.1 sessions not opening with my LE6.4 setup matthutchison 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-23-2006 05:05 PM
"Vintage" controller setup for the Adventurous... Therminologist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-03-2005 07:02 AM
Opening LE sessions..? ptrbas Pro Tools M-Powered (Win) 2 04-07-2005 06:19 AM
