GPI or som
Hello to everyone!
I want to show some kind of sign on the video monitor in the studio room - when REC button is engaged. Is it possible to take the signal out of the Pro Control? Thanks |
Re: GPI or som
No. But the USD and SYNC I/O can do it.
-Eric |
Re: GPI or som
Thanks ekuehnl. Can you be more specific? Cheers
Re: GPI or som
GPI (Relay) Description: Four pairs of SPST contacts, normally open Load (while switching): .5 A max at 200 VDC Load (continuous): 1.5 A max at 200 VDC Operate/Release Time: 1 ms Repetition Rate: Frame-rate max Latency: Half frame max In other words, there are fairly extensive GPI capabilities on the Sync I/O. You can use the GPIs to control a variety of external devices. Using one of the relays to turn a record light on and off should be pretty easy. Download the guide if you want to see the pinout information. -Eric |
