Old 02-20-2007, 08:26 AM
andre tchmil andre tchmil is offline
Default simple copy makes PT quit, Even more questions now
major problem her,
selecting region, then apple/C makes PT quit.
PT 7.3.1
all my plugins are installed but only click is active.
I trashed the DAE prefs but no luck.
Help!!!!
Old 02-20-2007, 09:23 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: simple copy makes PT quit, help please !!!
You need to trash "all" the prefs and the Digi database files!
the troubleshooting thread describes how to do all this!...
http://duc.digidesign.com/showflat.p...fpart=1#177661
Also try opening a new session and use "import session data" as your session may have become corrupt!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-21-2007, 03:48 PM
ok, still major proiblems here.
uninstalled PT 7.3, reinstalled PT7.2 first.
Copied session to another drive.
Imported files in new empty session.
Ran Diskwarrior on boot and audio drive.
Tried ALL the troubeshooting tips from the DIGI site.
Pulled out and reinserted RAM on the G5.
Pulled all plugins out of the Plugins folder, except the stereo mixer.
OSX 10.4.7,
G5 dual 2.7, 2G Ram
all of this couldn't solve my problem.
I explain again, select region, apple/ C ( copie) , or drag the region, makes PT spin the wheel of death.
Look, I'm a protools user since version 4.0 !!! , so I guess I can troubleshoot PT.
But now, I'm really really desperate.
Old 02-21-2007, 04:12 PM
Craig F Craig F is offline
check to see if the file is set to read only or no access permissions
Thank you,
Craig
Old 02-21-2007, 04:52 PM
if you mean drive set to record or transfer in the workspace browser, then yes ythey are set for record
Old 02-21-2007, 08:18 PM
no the singular files and or folders
did this session come in off of CD/DVD?
Thank you,
Craig
Old 02-22-2007, 12:22 AM
Access permission on all files
Own session on my usual audio drive.
Copied the whole to another drive just to check, same
Old 02-22-2007, 12:38 AM
tj_davies tj_davies is offline
Does this happen with any audio file, or just that peticular one. If it's just the one, either try consolidating it in the session (hence creating a new file) or converting it with another application, eg quicktime, and see whether Pro Tools behaves differently with the new file.
Hope this helps.
Timothy
Mac Studio Ventura 13.6
PT 2020.12.0
www.pearls-music.com
Old 02-22-2007, 01:06 AM
Hope this helps.
Timothy
I tried that, did an audiosuite process on that file as well, copied the file to another drive,
made a new session and imported, etc.
What I notice , even after reinstalling PT, that the object grabber for that session is on the seperation tool by default.
What else can I do besides , reinstalling the whole OS ?
Old 02-22-2007, 01:08 AM
Is it just that one session and/or that one audio. Because if it is, I doubt that reinstalling will help you, as it then sounds like the session and/or the file is corrupt.
Timothy
PT 2020.12.0
MC Control makes pro tools unexpectedly quit. filmsound_no macOS 5 08-19-2013 10:26 AM
Transfuser makes PT quit RaySoul Virtual Instruments 22 09-29-2009 01:59 PM
Copy - paste special - McDsp AC 1 quit x 2 crizdee Pro Tools TDM Systems (Mac) 0 02-01-2008 12:43 PM
A Simple Porblem I Can't Figure Out - Copy Regions Spyda KB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 01-20-2007 01:23 PM
MIDI makes PT6.4 quit unexpectedly + cs9 question bluerockgod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-18-2004 06:00 AM
