Old 02-10-2020, 03:10 AM
jane90 jane90 is offline
Default Shift click and Cmd click stopped working PT 2019.10
Hi everyone!
Some of the most basic shortcuts don’t work anymore. I recently upgraded from PT 12 to PT 2019.10 (Ultimate). Unfortunately, I can’t remember 100% whether this issue did occur together with the upgrade or appeared later. If I am not mistaken though I think it first worked in PT 2019.10 Ultimate and occurred only later on while having started already working with this version.
There are some previous posts addressing some of the issues for previous versions of PT, but unfortunately none of them seems to have solved them. So I am trying my luck again.
I have trashed all preference and database files.
Please note that I have a PC (HP Elite Book 850 G3) and a windows system, my keyboard is set to US English and when I below speak about the shortcuts, I refer to the Mac shortcuts, but am fully aware of the fact that in windows cmd is ctrl, opt is alt etc...
For more info I have pasted the Sandra Report below.
The issues and questions are as follows:
A) shift-clicking with the grabber tool to select multiple vertically adjacent clips doesn't work.
When just performing the standard grabber tool shift-click, it would only select the last clip in addition to the first, but all clips in between are not getting selected. Strangely, it does work to select horizontally adjacent clips with shift-clicking. The only way to select multiple vertically adjacent clips at the moment is either to select the first clip, and then shift-click on the track (name) of the track of the last clip to be included in the selection, or shift-clicking every single clip I want to include.
On the other hand, there is also a problem when selecting non-adjacent clips:
For selecting non-adjacent clips vertically I currently have to press shift. If I press command, the selection would jump to the second clip I clicked on.
For selecting non-adjacent clips horizontally, there is no way I currently can do that: When pressing command, the selection jumps to the second clip I clicked on, when pressing shift command, all clips in between get selected as well.
Please note that also de-selecting single clips with cmd clicking doesn't work at all.
B) is there a shortcut for de-selecting all tracks without using the mouse?
Obviously, I can option-click/click but I thought there might be a more efficient way to do this?
C) is there any way move or copy-paste clips including the content of their respective playlists underneath without actually opening up all the playlists, and selecting all clips of the playlists to make sure playlist content gets moved/copied alongside?
D) Is there any short cut to de-select the first or last clip in a row of multiple horizontally selected clips similar to ctrl+opt+ P or ; for de-selecting vertically?
E) Is there a shortcut to snap the selection going past a clip back to the clip end or snapping the selection starting before the clip to the beginning of the clip.
Thank you very much in advance!
SiSoftware Sandra
ID
Host Name : NBBOX01
Workgroup : WORKGROUP
Computer
Model : HP EliteBook 850 G3 103C_5336AN G=N L=BUS B=HP S=ELI
Serial Number : 5CG62*****
Chassis : HP Notebook
Mainboard : HP 8079
Serial Number : PFLAP00*******
BIOS : HP N75 Ver. 01.16 06/08/2017
TPM - Trusted Platform Module : IFX 1.2 (PCR 24)
Intel vPro : 11.0.0.1202
Total Memory : 16GB SO-DIMM DDR4
Processors
Processor : Intel(R) Core(TM) i7-6500U CPU @ 2.50GHz (2C 4T 3.09GHz, 3.1GHz IMC, 2x 256kB L2, 4MB L3)
Socket/Slot : FC BGA1356/1528
Chipset
Memory Controller : HP EliteBook 840 G3 100MHz, 2x 8GB SO-DIMM DDR4 2.13GHz 128-bit, Integrated Graphics
Memory Module(s)
Memory Module : HMA41GS6AFR8N-TF 8GB SO-DIMM DDR4 PC4-17100U DDR4-2132
Video System
Monitor/Panel : AU Optronics Generic PnP Monitor (1920x1080, 15.5")
Video Adapter : Intel(R) HD Graphics 520 (24CU 192SP SM5.5 1GHz, 768kB L2, 1GB DDR4 4.27GHz 128-bit, Integrated Graphics)
Graphics Processor
OpenCL : AMD Radeon R7 M365X (384SP 6C 825MHz, 1GB DDR5 64-bit)
OpenCL : Intel(R) HD Graphics 520 (192SP 24C 1GHz, 512kB L2, 6.4GB DDR4 4.27GHz 128-bit, Integrated Graphics)
D3D 11 : AMD Radeon R7 M365X (384SP 6C 825MHz, 1GB DDR5 64-bit)
D3D 11 : Intel(R) HD Graphics 520 (192SP 24C 1GHz, 768kB L2, 128MB DDR4 4.27GHz 128-bit, Integrated Graphics)
OpenGL : AMD Radeon R7 M365X (384SP 6C 825MHz, 1GB DDR5 64-bit)
Storage Devices
SAMSUNG MZNLN512HCJH-000H1 (512.1GB, SATA600, M.2, SSD) : 477GB (C:) (D:) (E:)
Logical Storage Devices
SYSTEM : 1GB (NTFS, 4kB) @ SAMSUNG MZNLN512HCJH-000H1 (512.1GB, SATA600, M.2, SSD)
Windows (C:) : 453GB (NTFS, 4kB) @ SAMSUNG MZNLN512HCJH-000H1 (512.1GB, SATA600, M.2, SSD)
HP_RECOVERY (D:) : 20GB (NTFS, 4kB) @ SAMSUNG MZNLN512HCJH-000H1 (512.1GB, SATA600, M.2, SSD)
HP_TOOLS (E:) : 2GB (FAT32, 4kB) @ SAMSUNG MZNLN512HCJH-000H1 (512.1GB, SATA600, M.2, SSD)
Peripherals
LPC Hub Controller #1 : HP EliteBook 840 G3
Audio Device : HP EliteBook 840 G3
Disk Controller : HP EliteBook 840 G3
USB Controller #1 : HP EliteBook 840 G3
Printers and Faxes
Printer : Send to Microsoft OneNote 16 Driver (1200x1200, Colour)
Printer : Microsoft Software Printer Driver (300x300, Colour)
Printer : PDF24 (4000x4000, Colour)
Printer : Microsoft Print To PDF (600x600, Colour)
Printer : HP Universal Printing PCL 6 (600x600, Colour)
Printer : HP ENVY 5000 series PCL-3 (1200x1200, USB, Colour)
Printer : HP ColorLaserJet MFP M278-M281 PCL-6 (V4) (600x600, Colour, Duplex)
Printer : KODAK VERITE 65 PLUS (600x600, USB, Colour)
Printer : Canon MG6200 series Printer (USB, Colour)
Sensors
Network Services
Network Adapter : Bluetooth Device (Personal Area Network) (Ethernet)
Network Adapter : Kaspersky Security Data Escort Adapter (Ethernet)
Network Adapter : Kaspersky Security Data Escort Adapter #2 (Ethernet)
Network Adapter : Intel(R) Ethernet Connection I219-V #2 (Ethernet)
Mobile Broadband Adapter : HP lt4120 Snapdragon X5 LTE (GSM, HSPA+)
Wireless Adapter : Intel(R) Dual Band Wireless-AC 8260 (802.11n (HT), AES-CCMP, 130Mbps)
Power Management
Battery #1 : Hewlett-Packard Primary 37.80Wh/2.95Ah
Operating System
Windows System : Microsoft Windows 10 Professional 10.0.18362
Platform Compliance : x64
Old 02-10-2020, 07:48 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Shift click and Cmd click stopped working PT 2019.10
Hi, welcome to the community. I needed to manually approve your post which was apparently too compliex at the moment. You need few simple posts published before these, or posts with links, are okay.
Janne
Click track has mysteriously stopped working UndergroundLab Pro Tools 12 10 12-23-2021 04:20 PM
SOS PT Ultimate 2019.6 stopped working _ and cannot install again BiggiT Pro Tools 2019 19 09-24-2019 06:29 PM
click track stopped working. nerhal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-12-2011 11:48 PM
the Shift+Alt+Pom+click command groovbro Pro Tools TDM Systems (Mac) 3 10-26-2008 06:45 PM
shift-click on reload tom tafuto General Discussion 0 11-24-1999 09:40 AM
