Old 06-23-2012, 05:45 PM
danbro2012 danbro2012 is offline
Default Pro Tools Instalation Failure (macbook pro/eleven rack)
Protools 8 LE 8.0.1
13" Macbook PRO 2.8Ghz intel Core i7 4GB Ram (1333 MHz DDR3)
Eleven Rack Hardware (not upgraded to ERXP)
I put instal disc in, and at the end a window pops up saying THIS:
System extension cannot be used
The System extension "/System/Library/Extensions/
DigidesignElevenRack.kext" was installed improperly
and cannot be used. Please try reinstalling it, or
contact the product's vendor for an update.
The "Install Pro Tools LE 8.0.1" Window also says THIS:
The Instalation failed.
The item you are installing from is damaged. Try
installing from a different copy of the item or contact
the manufacturer for a replacement
Which is a bunch of garbage because i installed protools on my desktop iMac with no troubles.
I downloaded the drivers for the Eleven Rack, and installed them, ... still the same error. I plugged in the eleven rack hardware, which i dont think you are suppose to do, ... and still same error message.
Help Please!
(im posting this in both Pro Tools LE Mac Systems and All things Guitar forum threads)
Old 06-23-2012, 11:12 PM
moff moff is offline
Default Re: Pro Tools Instalation Failure (macbook pro/eleven rack)
What version of OS X on the MacBook?. PTLE 8.X does not work on Lion.
MacBook Pro Not Recognizing Eleven Rack Archalen Getting Started 11 01-19-2014 07:00 PM
Communication with Eleven Rack Failure thomas-m Windows 19 03-13-2013 01:48 PM
Retina MacBook & Eleven Rack? jc7 Eleven Rack 9 01-02-2013 07:59 PM
Experiences running Eleven Rack with a USB3 MacBook Pro or MacBook Pro Retina? Darryl Ramm Eleven Rack 3 09-18-2012 11:22 PM
Pro Tools Instalation Failure (macbook pro/eleven rack) danbro2012 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-23-2012 07:15 PM
