Old 01-16-2012, 09:52 AM
pipepro pipepro is offline
Default ProTools 10 compatibility with Focusrite ISA ONE digital card
I have the Focusrite ISA ONE and I would like to know if the digital A/C card it has works as a third party interface to record with the new ProTools 10.
Anyone knows???
Old 01-16-2012, 10:34 AM
nst7 nst7 is offline
Default Re: ProTools 10 compatibility with Focusrite ISA ONE digital card
It doesn't work as an interface. Your best option is to get a cheap interface with a digital input and hook it up to that.
Old 01-16-2012, 01:48 PM
panamajack's Avatar
panamajack panamajack is offline
Originally Posted by pipepro View Post
...[concerning] the Focusrite ISA ONE...[will its] digital [A/D] card...work as a third party interface to record with the new ProTools 10?
If you are using a Mac Pro, you can run PT10 using only the built-in audio. Because the Mac Pro includes optical SPDIF I/O, you could connect the optical SPDIF out from the digital option of the ISA ONE (via TOSLINK connector) directly to the Mac Pro. You will have very limited I/O, but if a pair of input and a pair of output is all you require (for instance, if you want to do location recording of a soloist), it is possible to connect the ISA ONE directly to the Mac Pro without any interface other than the built-in audio. You would take the Mac Pro's analog line out and route it back to the external input on the ISA ONE to monitor any existing tracks, and disable the ISA ONE's "cue mix" to eliminate latency. In this mode, you can only record one channel.
Your input would be limited to 96KHz, even though the ISA ONE can do A/D conversion as high as 192. This is a limitation of the Mac Pro's optical port.
A dedicated interface would provide you with much more flexibility, but maybe if you are only recording a single acoustical instrument this would be adequate.
Focusrite isa 220/430 digital card for sale paulyd2 Buy & Sell 0 01-01-2013 10:40 PM
Focusrite Penta Digital Card tucum 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-26-2005 01:35 PM
Focusrite MH-442 ...digital expansion card -HELP soundpunk General Discussion 2 01-13-2005 07:15 AM
Focusrite optional digital output card mentalmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-25-2002 08:56 PM
Focusrite ISA 220/digital card/001 mhvoiceuk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-21-2002 01:59 AM
