Old 01-31-2011, 01:14 PM
pie55 pie55 is offline
Default 96 I/O with Aurora 16
Hello,
I'm going to buy a 96 I/O and use it in my hd2 system.
I currently have a Aurora 16 converter.
My question is do I plug the 96 into the expansion port of the Aurora or do I connect it to the HD process card?
Thanks
Old 01-31-2011, 01:17 PM
Ghengis Ghengis is offline
Default Re: 96 I/O with Aurora 16
Either or will work. I think if you plug your 96i/o into the process card you can run the Aurora in 32 channel mode (16 analog, 16 aes) That is the only advantage. Disadvantage is that you then need a longer digilink cable to get to the 96 i/o as opposed to the 30cm one that you can piggy back them together.
cya
Ghengis
Intel I7-930
Asus P6T-Deluxe V2
6gig Triple Channel 1600mhz
HD2 PCI, 96 I/O, Command-8
Win7x64
Old 01-31-2011, 02:54 PM
Third Eye Studios Third Eye Studios is online now
Ghengis is correct. I'd suggest plugging each interface straight to its own card, and utilize your Aurora in 32 channel routing mode.
Using the Aurora in advanced routing mode will keep Pro Tools' delay compensation on channels 9-16 correct.
https://www.thirdeyerecording.com/
System Details:
Avid HDX x 2: HP Z6 G4 Dual 16-Core Intel Xeon Gold 6226R 2.90 GHz, Lynx Aurora 16 LTHD x 6, Digidesign 192 i/o x 2, Pro Tools Ultimate 2024.6, D Command w/ Xmon
Old 02-08-2011, 03:22 PM
I'm a little confused. I'm using an Aurora 16. Do you mean channels 17-24 to do with the delay compensation?
Old 02-09-2011, 07:02 AM
Sorry for any confusion. I'm just suggesting that each interface be connected to it's own HD card. Doing it this way, the Aurora can be used in 32 channel mode (and it will show up in Pro Tools as two Digi 192 interfaces and will be sample accurate to the 192s converter latency).
If you were to connect the 96 i/o and the Aurora to one HD card, and use the Aurora in 16 channel mode, there is something you should realize about i/o 9-16 on the Aurora. Pro Tools will not be able to properly compensate for the latency on 9-16.
Below copied from page 9 of the Lynx LT-HD Manual:
"Since ProTools will only display 16 analog inputs and
8 analog outputs (this is a limitation of the 192 I/O that the Aurora mimics), the Aurora has been
programmed so that Analog Outputs 9-16 are mirrored by Digital Outputs 1-8 when in 16-
channel mode."
System Details:
96 I/O + ADAT I/O or 96 I/O + Aurora 16 josephm Pro Tools TDM Systems (Mac) 0 10-26-2010 07:05 PM
aurora 16 ad/da univox1 Tips & Tricks 4 10-28-2006 01:39 AM
Aurora Fuse-X Jon_Atkinson Pro Tools TDM Systems (Mac) 7 08-16-2005 11:51 AM
Aurora vs. Syntheszier One scottkchurch Pro Tools TDM Systems (Mac) 11 11-05-2004 05:36 AM
Where to buy an Aurora Fuse? Saar Pro Tools TDM Systems (Mac) 3 04-21-2002 09:01 AM
