Old 01-11-2008, 02:03 AM
Tuur Tuur is offline
Default 002R + mini me
Yo people,
I've connected my mini me with spdif to the 002R but i get even with the mic gain button on 0 a very loud input, What is going wrong?? and how can ii change this?
Thanx
Tuur
macbookpro 17" 2gig ram
dell 8250
Mbox 2
Digi002R
StudioTuur
Old 01-11-2008, 05:09 AM
Default Re: 002R + mini me
bump
dell 8250
Mbox 2
Digi002R
StudioTuur
Old 01-12-2008, 06:47 AM
please help i don't understand.
Somebody?
Tuur
www.studiotuur.nl
dell 8250
Mbox 2
Digi002R
StudioTuur
Old 01-12-2008, 03:13 PM
queenstonmusic queenstonmusic is offline
Are you trying to daisy chain your mbox to your 002?
Old 01-13-2008, 08:58 AM
No, i try to record track 17 and 18...
The mics go into the mini me and then spdif to the digi...
mini me is master and ad8000 (behringer ;-( is slave clock.
I just get a lot of gain. even with the volume on mini me pre's on 0. The soft limiter puts it on 0db but i like no signal when volume is 0....
Anybody?
Tuur
dell 8250
Mbox 2
Digi002R
StudioTuur
Old 01-13-2008, 05:28 PM
Ziko Ziko is offline
Hi Tuur.
As the signal coming out of the spdif outs on the mini-me is digital, your gain issue must be on the mini-me itself, Pro Tools isn't amping it at all, it's just receiving a stream of digital data.
The mini-me has two gain settings for each channel that can be set by some jumpers inside the device. Out of the box, both channels are on the higher gain setting, try dropping both to the lower setting. I did on mine and I find it much better, the signal is never too low as with 24 bit recordings signals, levels sitting at around -18 to -12db are just fine.
You won't however get it to read 0 when you drop the gain level to 0 as the mic pre is still engaged, turn it left until it clicks though and that'll turn the mic-pre off (for line level inputs). You shouldn't see much if any level then.
Check the manual for how to swap the jumpers, it's very straight forward. private message me if you have trouble.
Cheers,
Simon
oh and by the way, how have you done your clocking with 3 devices all needing one master? The mini-me has to be master so you must have the 002R set to use spdif in as clock source. What do you then set the AD8000 to? Do you tell it to clock from the 002R?
Macbook Pro 2.4 GHz, OSX 10.5.5, PTLE 8 + MPT, 003R Factory, Apogee Mini-Me
Old 01-14-2008, 03:37 AM
Hi Ziko (Simon),
Thanx, i'm gonna try that. I think there's my problem.
About the clock: i put the sync of the behringer to slave.
I now record 11 tracks of drums and clock on the mini me.
No ticks or what so ever.
Cheers
Tuur
NEW!!
www.studiotuur.nl
dell 8250
Mbox 2
Digi002R
StudioTuur
M Box 2 mini won't run pro tools but 002R will Barton Audio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 07-23-2009 11:54 AM
002r V M Box Mini rabs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-16-2007 10:33 AM
002R and Apogee Mini Me? tim carter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-14-2007 01:51 PM
Connecting 002r to mac mini grandmastrmahoy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-19-2005 08:55 AM
002r or Mini-Me brianpatrick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 07-08-2003 03:47 PM
