DSP Mode Vs Native Mode
Has anyone noticed how other tracks go off timing when DSP mode is enabled?
every time I press record, the stacked vocals go off time. Is there a reason or a way to fix this? I only notice it happening on DSP mode. When I go back to native mode, everything is still on time. it just would be nice to be able to listen to everything in sweet harmony.
Take care brush your hair, Rey https://r-e-y.com/ macOS Ventura Pro Tools 2022 iMac (Retina 5K. 27-Inch, 2020) Processor 3.6 GHz 10-Core Intel Core i9 3.6 GHz Dual-Intel Core i7 16GB ram AMD Radeon Pro 5700 8GB Shure SM7B Mic Pro Tools | Carbon Komplete Kontrol M32 AKAI Mpk3 Mini KALI Lp 6 (2) |
Re: DSP Mode Vs Native Mode
To clarify do you have those vocal tracks in DSP also, or perhaps in Native with Native only plugins on them ? And do you have Automatic Delay Compensation , active ?
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... |
I also notice that while I'm able to monitor my mic without pro tools, I can only hear my Roland FA 06 through my Digital Audio Workstation. The Carbon is set to the proper channel, input and volume--still, no sound unless I'm on a DAW. I ask because If I use the Apollo Twin X mk2 quad, it'll let me hear what I am playing whether I am on or NOT on Pro Tools. There Is signal, I can see the notes from the instrument input on the Carbon channel but no sound is coming out of my monitors.
Take care brush your hair, Rey https://r-e-y.com/ macOS Ventura Pro Tools 2022 iMac (Retina 5K. 27-Inch, 2020) Processor 3.6 GHz 10-Core Intel Core i9 3.6 GHz Dual-Intel Core i7 16GB ram AMD Radeon Pro 5700 8GB Shure SM7B Mic Pro Tools | Carbon Komplete Kontrol M32 AKAI Mpk3 Mini KALI Lp 6 (2) Last edited by ReynaldoPena; 06-24-2021 at 09:34 AM. |
Hi Rey,
For the “off time” issue, will you install 2021.6 (released today) to see if that fixes it? For the monitoring issue, Carbon doesn’t have software like the Console application that Apollo has for standalone monitoring. To monitor an input you need to use a DAW like Pro Tools, Logic, Reaper, etc.
Kyle Splittgerber Senior Principal Product Designer Avid Berkeley, CA |
Any know how a keyboard shortcut to enable and disable DSP mode?
If you have different processing on your stacks of vocals that will do it. Delay compensation is *not* active on DSP plugins on record enabled/input monitored tracks. By design.
For example, if you set up two tracks to input 1 and put an AVID DSP plugin on one (10 samples) and a Plugin-Alliance plugin on the other (34 samples) you'll get crazy comb filtering. Solution is doing just like Apollo Console or old TDM days — same plugin across each channel of phase critical sources. The benefit of doing it this way is you could have 2.5 extra ms of latency on a guitar input (3 PA plugins), where the 3-4ms won't be noticeable, and it won't stop the vocal input with AVID channel strip from still only being 1ms latency. |
Just disable auto low latency on the track (blue mode)
I was able to fix the problem. I turned off delay compensation and everything sounds much better. Thanks.
?? Care to expand? That sounds the opposite of what I'd expect.
Thanks y’all |
S3 bug: track exits trim mode after writing send automation in preview mode | yoerik roevens | Avid S1, S3, Dock and Control App | 4 | 06-27-2017 10:38 PM |
Starting PT|HD in native mode | Glazik | Pro Tools 11 | 13 | 08-08-2013 03:58 AM |
Input mode and virtual sound check mode | gagaiop | VENUE Live Sound Systems | 1 | 07-15-2010 11:37 PM |
Grid mode, shuffle mode, spot mode and slip mode. | RogTaylor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-24-2010 10:30 AM |
mono mode vs multi input mode in Audio Suite plugin? | thenewnoise | Pro Tools TDM Systems (Mac) | 4 | 09-30-2009 06:58 PM |
