Mbox 2 Pro Input Monitoring constantly, even with No Tracks in Pro Tools 11
I have a legacy Mbox 2 Pro (2nd generation I think - the blue face one). Just upgraded to Pro Tools 11 and installed the newest available MBox2 Pro drivers from the Avid site.
Input audio is passing through the Mbox and out the Monitor and Headphone outputs even when no tracks are record enabled. Same thing even when no tracks are created in a (blank) session. Happens with both the SPDIF and Analog inputs. It makes no difference if I switch between Input Only Monitoring and Auto Input Monitoring. As an experiment, I set the Hardware Buffer Size to the maximum setting and turned off Low Latency Monitoring. The resulting latency allows me to hear when audio is being monitored via the computer vs. direct from the Mbox. I hear the delayed audio monitoring as it should (Auto Input Monitoring: switches from input to playback; Input Only Monitoring: monitors delayed Input Audio over playback). Problem is the Hardware-Direct audio never goes away, ever. Until I quit Pro Tools, then everything flows as it should, for instance I can play a quicktime audio file through my monitors and the Mbox doesn't pass any input audio. Obviously this is a problem when recording in the same room as monitors (feedback). I never had this problem with PT 10. Is there some strange MBox 2 Pro issue? System: Macbook Pro 2012 2.4 Ghz i5 8 MB RAM MBox 2 Pro (2nd Gen Blue-Face edition) |
Re: Mbox 2 Pro Input Monitoring constantly, even with No Tracks in Pro Tools 11
I have the same issue
any fix?? |
I managed to fix this .....
first you open pro tools 11 and you have input monitoring even if you don't open a session. ...now close pro tools 11 and open pro tools 10. 3.7 ....now you don't have input monitoring. ...close and reopen pro tools 11. ....input monitoring gone...so you re ready to record properly my machine is hackintosh with i7 3820..16 giga ram ..mountain lion 10.8.4 with the latest drivers for mbox 2 pro (for 10 and 11) hope I helped |
I am experiencing the same issue. I'm running an MBox 2 Pro (blue face, Firewire 400 connection) with latest driver, on a computer that has 11.0.2 and 10.3.7 installed.
Starting up a session in 11.0.2, any live input is routed through to the monitor outputs even when there are no tracks in the session. Saving and closing that session, and then opening it in 10.3.7, causes it to revert to prior correct behavior, inputs are only heard when record enabled on tracks in a session. Quitting 10.3.7 and relaunching the same session in 11.0.2, now that one behaves properly as well. Input audio is only heard when coming through a record-enabled track, and can be muted on the track if desired. But not for long. The corrective fix does not persist through a shut down and restart cycle. I have confirmed this is happening on two different Macs: a late 2012 Mini, and a late 2007 Mac Book Pro. The same symptom and temporary fix, but the fix doesn't last through a restart. In case anyone isn't familiar with the MBox 2 Pro, this is NOT one of the MBoxes that has a "Mix" knob that allows listening to live inputs, or output of a session, or a blend thereof. This box, up until PT11, had to do all its monitoring through the session. But now it has disturbingly gained live input monitoring that cannot be turned off! I have tried the smaller MBox 2 Mini on the two systems mentioned above, and they don't suffer from this problem with the MBox 2 Mini. Just the MBox 2 Pro (Firewire). This is a serious issue for me. Any ideas for remediation? Or has this interface just been unofficially obsoleted even though it's nominally still approved for PT11? |
I have this exact same issue as well, with the MBOX 3G. It's made recording with it exceedingly annoying and will be uninstalled shortly (going back to 10.3.7)
I'm late to the party but having the same issue. I don't suppose anyone has a resolution or viable workaround? Thanks!
Same here. Macbook. Mbox 3.
Has anyone found a fix for this issue?
I'm having this same problem. Thanks |
anybody?
MBox 2 Pro, OS 10.9.4, PT's 11.2.1 Pro Tools HD (CPTK upgrade)
No control of input monitoring (Bleed) Can't calibrate to system. PT's 10.3.9 is fine and the only way to track or calibrate. Tried the manual remove drivers reinstall legacy 10.3.3 drivers Tried the MBox 3 Pro drivers Short of the Exchange program to HD Native This box needs a legacy driver update before V11 can be accurately used. MBox2 pro to 3 pro exchange?
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
Input monitoring on armed tracks | mr.armadillo | Pro Tools TDM Systems (Mac) | 9 | 11-02-2012 10:13 AM |
Input Monitoring Mbox 3rd gen | [email protected] | macOS | 0 | 07-06-2012 09:05 PM |
Monitoring the Phono Input on an MBox 2 Pro | Alan Brownstein | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-04-2011 12:24 PM |
input monitoring on Mbox 3 - advice needed | pennyco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-11-2010 07:49 PM |
MBOX 2 Pro Input Monitoring | sepulchra | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-10-2007 03:59 PM |
