SOLVED : creating new session : Path to session contains illegal characters ( " )
Getting an error when creating a new session.
1) provide a name in the session create window 2) "Prompt for location" is marked 3) press "create" 4) Save dialogue comes up with the name on top 5) Direct to ANY folder or create a blank 6) press "save" error dialogue pops up : "Path to session contains illegal characters ( " ) " conclusion -> Can't create a session in ProTools 2022.9 Mac Pro 14" M1 Mac OS 12.6 -> ProTools Studio Update : When NOT selecting "Prompt for location" and manually set location in the button "location" it seem to work
Philippe Meiresonne (Belgium) http://www.pm-mastering-studio.com SYSTEM 1 : Main recording - HDX MAC Pro 2023 M2 Ultra Running Sonoma 14.4 ProTools Ultimate 2024.3| 1xHDX Card | Mac Pro M2 Ultra 128Ram 2TB|3x PRE | 2x Avid 96 |1x Avid 192 I/O 16/16 Analogue | 1x Acid HD I/0 16/16 Analgue Midi I/O | D-Command ES +16 fader Pack | Xmon | Eleven Rack + Dolby Atmos 7.1.4 Surround Adam S3H speaker System System 2 : Project System - ProTools CARBON Running Sonoma 14.4 MacStudio M2 Ultra |64 GB RAM | ProTools 2024.3 Ultimate/Studio | SSL2+ | AVID S1+DOCK + ProTools|Carbon + ProTools|Carbon PRE Last edited by pm mastering studio; 11-07-2022 at 09:30 AM. |
Re: 2022.9 -> creating new session : Path to session contains illegal characters ( "
Hi !
Followed your steps but couldn't reproduce here. Try deleting preferences just in case .
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
1) did dump the preferences (also tried with PT Prefs 2) - > same error
2) reïnstalled over the excisting version -> Same error 3) uninstalled with cleanmymac and reïnstalled 2022.9-> Same Error 4) uninstalled 2022.9 and reïnstalled 2022.7 -> Solved with 2022.7 so ... 2022.9 does something wrong maybe it's my French- keyboard ? (Belgium/french language setting) so I tried different keyboard settings - still no go ;-( I'll try to install 2022.9 this weekend on my MacPro with HDX and see what the result is. I'll be back ;-)
Philippe Meiresonne (Belgium) http://www.pm-mastering-studio.com SYSTEM 1 : Main recording - HDX MAC Pro 2023 M2 Ultra Running Sonoma 14.4 ProTools Ultimate 2024.3| 1xHDX Card | Mac Pro M2 Ultra 128Ram 2TB|3x PRE | 2x Avid 96 |1x Avid 192 I/O 16/16 Analogue | 1x Acid HD I/0 16/16 Analgue Midi I/O | D-Command ES +16 fader Pack | Xmon | Eleven Rack + Dolby Atmos 7.1.4 Surround Adam S3H speaker System System 2 : Project System - ProTools CARBON Running Sonoma 14.4 MacStudio M2 Ultra |64 GB RAM | ProTools 2024.3 Ultimate/Studio | SSL2+ | AVID S1+DOCK + ProTools|Carbon + ProTools|Carbon PRE |
found out more about this problem.
1. It still remains in 2022.10 ! 2. When I want to save on the internal disk of the MacBook Pro M1 the problem excist 3. It also excist when you want to "save as"/ "save copy" 4. BUT ! when I save a session on a removeable (USB/Thunderbolt) connected SSD all works great. Conslusion : there is something that blocks PT from saving to the internal Disc in certain cases ! please find included some screenshots of the issue. Please Avid. Could you solve this ?
Interesting. So what is the exact full path you're trying to safe to? Looks like 2022.10 is interpretating the disk name wrongly.
doesn't matter what path. desktop or root directory or even users/documents. as long as it's on the local drive it gives me the error.
Can u create it on external drive, move it to internal and open/re-save it on internal?
Also what is exact path?
__________________ Al Hospers bassist, vocal, composer, engineer https://www.youtube.com/channel/UCCw...ogfR_7Q/videos ------------------------------------------------------ PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones... |
Tried your workarround but didn't solve the issue. kind regards
But it does matter what the path is - if you have named your internal hard drive HD"1 then it contains an illegal character. That's why we're asking.
HA JJ !!
you've given me the solution ! Apparently my internal SSD was named MacBook M1Pro HD 14" after renaming it to MacBook M1Pro HD 14inch all worked ! THANKS ! feel a bit stupid not have seen this ;-(
path to session contains illegal characters | rebelcowboy | Pro Tools 10 | 7 | 06-07-2019 06:20 PM |
"Path to session contains illegal characters" | beschaving | macOS | 5 | 07-30-2013 01:42 AM |
path to session contains illegal characters | evankertman | Pro Tools M-Powered (Mac) | 7 | 04-28-2009 03:09 PM |
path to session contains illegal characters (/) | basslik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-20-2008 08:22 AM |
Path to session contains illegal characters (/). | Haiku | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-18-2007 09:30 AM |
