Old 10-24-1999, 09:05 AM
Jerome B Jerome B is offline
Default Dolby surround Tools
I just bought the plug in. The manual is relatively clear. However, I have one question: When I put a simple stereo music track, assigned to the Left and Right input of the encoder, I always get a lot of sound in the surround. Is this normal ? Is it possible to send something only in the left and right output ( and some center leak) but not in the surround ? There's a paragraph in the manual that talks about creating surround inetrior effects, by sending a bit of Left and Right information into the surround...I don't have to. I always get a lot ??
Old 10-24-1999, 01:59 PM
Branko's Avatar
Branko Branko is offline
Default Re: Dolby surround Tools
Jerome,
Dolby Stereo is a four channel matrix system which (this is very, very simplified) works this way: it derives center and surround information from both Lt and Rt tracks (these are master Left and Right). If a signal is recorded on both tracks, and the phase between these two is 0°, then it will be decoded to center. If the signals on Lt and Rt are same level, but out of phase for 180°, it will be decoded as surround.
Consequently, you may conclude that your stereo mix either has a lot of out-of-phase information (e.g. reverbs, string pads, etc.), or there is a major phase problem between L and R. Check for these two cases before trying anything else.
Branko
Branko Neskov c.a.s.
www.loudness-films.pt
Dolby Surround Tools, AAX??? jonathon_l AAX Plug-ins 2 08-16-2012 06:37 AM
Dolby Surround Tools in PT 5.1.3? synthetic Pro Tools TDM Systems (Mac) 1 07-03-2002 04:20 PM
dolby surround tools Tom_Weber Pro Tools TDM Systems (Mac) 3 04-09-2001 10:47 AM
Dolby Surround Tools & PT 5.1 Digital One General Discussion 1 12-18-2000 06:56 PM
Dolby surround Tools with PT 5.1? Stjernholm General Discussion 9 11-14-2000 12:20 AM
