Distortion
Tonight, I momentarily switched from my Digi 002 to a Presonus StudioLive. (I wanted to test it with my D-Command.) The monitoring didn't seem to work at first, and I had work to do, so I switched it right back. That's when the distortion started. It's almost like PT is about 20 dB hotter than it was a few minutes ago. Even when I bounce files, the resultant waveform is now an almost solid rectangle... no dynamic range to speak of... and crazy distortion. Why?
Also: I attempted to throw out my pref files. I could not find any com.digidesign.plist (or anything obviously attributable to PT, Avid, DigiDesign) in my preferences folder. Is it normal now to have no pref files? -DaleB (Pro Tools 9. Digi 002. Mac tower 8 core. Snow Leopard. D-Command.) |
Re: Distortion
I just upgraded to PT10. That didn't fix the problem. It's still distorted. Arg.
Re: Distortion
the name of the ProTools prefs file is "Pro Tools Prefs". It is located at: HD/Users/your user account name/Library/Preferences/Pro Tools Prefs. If you cannot see your user library folder, then keep alt key pressed while you click on "Go" within Macs menu bar.
Cheers, STeff --------------------------------------- MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected OSX10.15.7 Pro Tools|HDX Ultimate 2023.6 HD I/O&192Digital&96&96i I/Os D-Command ES 4xUnitor8 & 2xAMT8 |
RMS and distortion. | yamahadrums | General Discussion | 4 | 11-06-2012 11:21 AM |
Distortion... | Fortydub | Windows | 2 | 01-30-2012 09:58 AM |
distortion help | robgreen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-12-2005 02:59 AM |
002 Distortion | tg4878 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-19-2004 07:47 AM |
Distortion | Mark Tandy | Digidesign Hardware & Software | 2 | 05-17-2001 10:13 PM |
