fast track pro pre amp noise
hello i recently bought the pro tools 9 bundle with the m-audio fast track pro. i wanted to get a condensor mic just for basic recording at home, something to quickly get ideas down and go to the studio afterwards to re-record for the finished product but the mic pres in my fast track aren't that good and in order for me to get a acceptable signal i would have to turn up the gain to like 95 percent to get a good level and its a bit noisy. now is there a way to get rid of that noise after i record. is there any plugins i can use that pro tools comes with that can take out that noise or will it be a hassle every time and should i not even bother ? i heard a gate compressor will do the trick, correct me if im wrong.
Re: fast track pro pre amp noise
Yeah you could use a gate or manually apply fades to get rid of the noise when there's nothing else present, but I would look for a better solution. At least try to get rid of the noise - could be a grounding issue with your setup, or a faulty unit. You could try it in some different locations or on a different computer to see if you still have the noise. I used to have a Fast Track Pro and they are decent, but not Pro quality IMHO. Best solution if all else fails is to get a better interface.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
or get a better mic.
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey Alesis Masterlink, Alesis Adat LX20, , Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon, Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric. http://www.johnackermusic.com/ [email protected] Live and Let Live |
True, your mic could be the cause of the noise, but even the best mic isn't going to sound as good as it should if your preamps and converters aren't up to snuff - I know this from personal experience.
Fast Track Duo Burst of Noise | bemol | FireWire & USB Audio Interfaces (Win) | 8 | 03-23-2015 11:49 AM |
Fast track pro constant noise problem (an ear killer !!) | nircc1 | FireWire & USB Audio Interfaces (Win) | 2 | 08-25-2013 09:52 PM |
Noise appearing when using M-Audio Fast Track Pro | RURTOS | FireWire & USB Audio Interfaces (Win) | 1 | 05-06-2013 06:02 PM |
Monitor Noise w/ Fast Track | adm6166 | Pro Tools M-Powered (Win) | 0 | 01-17-2013 04:36 PM |
Fast Track Ultra back ground noise | deanobeano | Windows | 0 | 10-31-2011 07:55 AM |
