Old 02-05-2011, 11:05 AM
frostit frostit is offline
Default pro tools doesn't start I need help
when I try to start pro tools I get this error msg.
[Pro tools 9 cannot run due to the following error:
this product cannot run because of problems communicating with core component. Please try reinstalling the software. If that fails, contact the software publisher for support.]
and after that msg it gives this error [ error, missing ilok authorization for pro tools 9". please insert the necessary ilok to continue.]
I so tired of this I spent 600$ for software that I cant use, avid needs to do something about this, my interface is a Presonus project mix, and I'm running snow leopard 10.6.6 on a mac pro. If any one has any idea whats wrong pleas reply thanks.
Old 02-05-2011, 11:59 AM
Dirt_ Dirt_ is offline
Default Re: pro tools doesn't start I need help
Have you installed the latest audio drivers for your project mix? Have you installed the iLok key? Have you even activated the PT license on your iLok? Tell us more about what you HAVE done to try to fix the problem. Also try to tell us about the steps you took from start to finish on the install.
-Mac mini i7 Quad 2.3, 4g ram, OSX 10.10.2, PT11.2.1, iLok 2.
-Apogee Quartet, 2 Profire 2626's.
Old 02-05-2011, 08:51 PM
I think I found what the problem is, when I open the digidesign coreaudio manager it shows unsupported device and the status is not connected HW not found. so I reinstalled the latest driver from presonus but still no success
Old 02-05-2011, 09:27 PM
slater05 slater05 is offline
Were there any hiccups getting the PT9 lisence on your ilok account?
www.mikeslatermusic.com
PTHD9 Certified Operator
15" MBP 10.7.2
Pro Tools 10.0
Apogee Duet
M-Audio BX5A's
Old 02-06-2011, 01:07 PM
yes iv done all that and no there was no hiccup when I added the PT9 lisence on my ilok account, It doesn't matter which usb port put the ilok it still asks for it. Is it possible that my presonus hardware is not compatible with PT9?
Old 02-06-2011, 01:24 PM
Avid's Avatar
Avid Avid is offline
Administrator
This thread on the Presonus forum is about a different device, but the last 2 posts may help:
Presonus forum thread
Administrator
Old 02-06-2011, 02:25 PM
yea I cant get pro tools to start, If i go to the applications folder click on the digidesign folder then go to digi coreaudio manager thats where it shows unsupported device and the status is not connected HW not found
Old 02-06-2011, 08:52 PM
heres a question is PT9 compatible with snow leopard 10.6.6
Old 02-06-2011, 09:44 PM
Noiselab Noiselab is offline
Yes it is.
Here's a question: Have you determined whether the HW can be seen by OS X's Audio/MIDI setup or another application like iTunes?
NL
Old 02-06-2011, 10:54 PM
Or a quick way to help see if it is a hardware problem. Try and startup pro tools on core audio without your presonus plugged in.
15" MBP 10.7.2
Pro Tools 10.0
Apogee Duet
M-Audio BX5A's
Lion Pro Tools SE won't start on one account, but start on another AndrewGalas Pro Tools SE and Essential (Mac) 2 12-15-2011 11:06 AM
Pro Tools won't start up? calicobumps 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-26-2010 09:28 AM
Pro Tools will not start up. Help khenninger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-12-2007 03:51 PM
Pro Tools won't start on my Mac Ralph Baumgardner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-11-2007 02:24 PM
Pro Tools 5.1 Session Start—Record Start Interval Avid Pro Tools TDM Systems (Mac) 4 04-18-2001 08:27 AM
