ScreenFlow and Protools
I want to make a Protools tutorial using Screenflow and a microphone connected to my Avid IO. I know i can use the Screenflow Telestream playback engine but that mutes all the inputs and thus my microphone. Are there any workarounds to get microphone and PT output into Screenflow? I checked out the LoopBack app without any results. Checked Dante Via but this gave me an immense delay on the microphone. Gets hard to talk naturally then...
Protools 2019.12, HighSierra 10.13.6, 2x2.66 Ghz 6 Core intel Xeon, 24 Gb 1333 MHz DDR3 |
Re: ScreenFlow and Protools
At Pro Tools Expert, we route the audio out of an HDX system and record the Mic and Pro Tools audio on a separate device. You could look at Source-Nexus from Source Elements to do the reroute of the audio out of Pro Tools, or change he playback engine to the Mac audio output and then tell Screenflow to record the computer audio. But I find using the separate device (in my case a ZoomR16) means that I have complete control in post of the Voiceover and the Pro Tools audio.
Hope that helps, Mike |
Hi Mike, Thanks for the tip. So after your screen is captured in screenflow and your audio in the Zoom. what app do you marry the two? Final cut? Premier? And how do you lock / sync picture to the sound? thanks in advance!
Best, Sean Sean McDonald Red Medicine Recording LLC Sofa King Music Services http://www.seanmcdonald.com |
Hi Sean,
To sync up I record a monitor mix of Pro Tools and my VO into my Mac audio input. Then at the start of the recording, I click my fingers for a sync mark. I edit and mix in Screenflow. When I import the audio files from my Zoom into screenflow, I line up the finger click, then delete the guide audio. Then I am good to edit and mix within Screenflow. Mike |
I'm encountering this issue now, as well. Recording an external microphone via an interface along with the stereo audio from Pro Tools and live screen capture seems to be a real issue for ScreenFlow.
I've been playing with various ways to get this to work. Mike- I can see why you would want to record on a separate, multi-channel audio device. I sure wish there was a better capture solution that could record multiple channels of audio synced with multiple video sources, ready for editing. I bet there is and I just haven't found it yet. Editing in ScreenFlow is a relative breeze compared to other NLEs so that is the draw for me there. One thing I've noted is that this may be easier with other DAWs that allow you to select a different "interface" or source for the audio input and audio output. This YT tutorial seems to be utilizing that feature of Logic: https://www.youtube.com/watch?v=RFaSj5O17n0 Ableton Live is the only other DAW that I use regularly that lets you choose different audio input and output sources. To be fair, REAPER also allows this but does not recommend using this "legacy mode". |
Pro Tools 12 and Screenflow App | juca2929 | Pro Tools 12 | 0 | 04-09-2017 06:15 AM |
Protools 12 - Input Audio Window Keeps on opening Protools Cache | soundman1234 | Windows | 0 | 08-25-2016 11:27 AM |
changing from protools 8 audio only to protools 8 with video support | djkaz | macOS | 5 | 09-04-2013 04:00 PM |
Anybody works with Screenflow and Digi? help!!! | Guy25 | General Discussion | 1 | 03-27-2009 11:41 PM |
setting record levels into ProTools with the intent of mixing in ProTools | Felix | Tips & Tricks | 507 | 02-05-2002 10:17 PM |
