Old 01-20-2013, 09:15 AM
wfenlon wfenlon is offline
Default Long delay before playing/recording
Using DIGI002 on my Macintosh, when I set up to play/record, there is a long delay before it starts working. This doesn't happen if I play a previously recorded session-only a new one. I get the circular rainbow for about 2 minutes before it kicks in. I think it's happened before but haven't done anything different that I know. Thanks in advance.
Old 01-20-2013, 09:21 AM
abeardslee abeardslee is offline
Location: Northeast Community College, Norfolk, Nebraska
Default Re: Long delay before playing/recording
I had this happen once, and I'll share what fixed it for me, but I'm not sure our two problems are related, but it sounds like it. Go to your system preferences... what is your default audio playback? Is it your DIGI hardware? If so, change it to the internal audio hardware and see if that helps.
Old 01-20-2013, 10:55 AM
sunburst79 sunburst79 is offline
If your disk allocation is set to "open ended" in the prefs try shorting it to something more reasonable in regards to your project. Like 15 minutes or so.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 01-21-2013, 09:08 PM
My playback engine is Digi002 and system preferences under Sound is Digi002 for sound input and output, which seems to have worked in the past. I had tried using delay compensation and thought that might be the problem. Increased buffer size and removed delay comp. It then worked correctly with a track record-enabled but when I actually pushed the record button to record the same problem happened again.
Not sure about disk allocation. I couldn't find a reference to its size.
Old 01-22-2013, 12:39 AM
Bob L's Avatar
Bob L Bob L is offline
Check Preferences > Operation > Record section (right side). There is a 98% likelihood that this is your culprit, if it's set to Use All Available Space.
Old 01-22-2013, 09:47 PM
Smile Re: Long delay before playing/recording
Looks like that solved the problem, though I never remember going to that page before. I was still getting the rainbow for about 3 seconds when i set the space to an hour so I lowered it more. What is a reasonable setting? Thank you so much- I would never have found this on my own.
Old 01-22-2013, 11:54 PM
Reasonable setting in my instance would be the average length of a song plus a buffer. I will say ten minutes max . If you were doing hour long TV shows you might want to change that to 65 minutes. If you were recording your band in a live setting you might want to break it down to 40 minutes and then treat each set as a separate session. Smaller sessions are going to make for quicker transport response. If all you do is 60 second voice overs set it to 2 minutes.
Scott
Core 2 Specs Page
Long delay before playing/recording wfenlon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-19-2013 07:58 PM
long delay when recording or playing back earworms 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-07-2009 03:01 PM
Long Delay before recording starts. Hekler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-19-2004 03:17 AM
Long (LOOOOOOONG) delay when starting recording yonkiman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-26-2002 01:27 AM
really long delay before recording begins Joseph Grimm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-09-2000 01:09 AM
