Compressor for mastering
What compressor plugin do you guys like for mastering? (single or multiband)
I don't do a lot of mastering myself, but for demo's for example I have to both mixdown and mastering in most cases. I like the Waves C4, but do you have any other plugins you like for mastering? Thanks! |
Re: Compressor for mastering
For compression in the mastering phase, I usually use the waves linear phase multiband, a calculator, a pencil, my ears, etc... For final limiting I've been using the L2 but have lately been thinking of going back to an outboard limiter. (just a side note, I never master inside of PT. I personally feel that PT just isn't as well equipped for this task as some other programs are; there are very few analysis tools inside of PT or even available for use with PT that have the kind of resolution I desire when mastering)
Cavell Studios |
I use waves linear multiband compressor and L2 as well.
Joz
"I never hit a women with her clothes on!" |
Soundsurfr MAC Mini, 2.3GHz dual-core i5, 8GB DDR3, 500GB Hard drive, 288MB DDR3 SD RAM M-Audio Firewire 1814 Yosemite OS |
Hmmm...
Try this order; -whatever you have available -whatever sounds best to your ears/project in question -whatever delivers your desired results Me, Myself and I...hardly use plugins...outboard SSL buscompressor or Summit DLC or TC Finalizer Plus or Studer D19 soft limit or...whatever I can borrow. In WaveLab though I'll often employ L1 or L2 before the final burn. cheers,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
Slightly off topic: What is the main difference between those Waves Linear Phase EQ's and the Q- or REQ EQ's? I am not familiar with the Masters Bundle from Waves. |
A linear phase vs. frequency response when the input is compared to the output.
Cavell Studios |
the C4 is good, just dont fall into the trap of letting it control you--ie those presets can mess up your mixes something quick
took me a long time to use this plugin the way i like. and remember, as person much wiser and more experienced than myself once said, mastering is all about monitoring. (and stop being lazy, go fix it in the mix and rebounce it:) B. |
Mixing / Mastering - Maxim Compressor ??? | udamann88 | Eleven Rack | 9 | 04-08-2011 08:38 PM |
Best PT LE Mastering Compressor/Limiter if Waves is not available? | GrievousAngel | Tips & Tricks | 17 | 11-30-2010 11:25 AM |
mastering limiter/compressor | tvjorg | Post - Surround - Video | 13 | 03-21-2009 05:44 AM |
best mastering eq and compressor and a/d d/ad/da | yaga | Tips & Tricks | 5 | 06-18-2003 07:45 PM |
who uses the renaissance compressor in mastering?...and some other mastering stuff... | djc8902 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 01-16-2003 11:14 AM |
