Old 07-17-2013, 05:46 PM
xiphos xiphos is offline
Default Best synth and drum instrument for PT11
Hi-new to the forum and PT. Coming over from Cubase, and I guess none of the VSTs I have will be of any use in PT11.
I would like advice/opinions on the best synth and drum VI to acquire first, with cost being a definite concern. I dont do a whole lot of synth work, so one synth VI with lots of flexibility and ability to run multiple instances should be sufficient for now. Also need a drum VI similar to toontracks DFH. I suppose Superior 2 will work, but its kinda spendy and maybe overkill for me.
thanks in advance.
Old 07-17-2013, 06:33 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Best synth and drum instrument for PT11
Reason vst into Pro tools via rewire
All ur vst's all ur same presets all 64bit
Daniel
Old 07-17-2013, 09:11 PM
FLi's Avatar
FLi FLi is offline
Xpand, the synth/sampler that comes with PT is really good, it works right across the board so maybe check that out before buying anything. The Korg Legacy Collection (digital edition) is also really good and balanced.
I used to own a lot of analog synths so that's where my headspace is but I also find the older synths (and their VI equivalents) tend to be a lot more versatile than the new synths. The Arturia collection would also be a great package to look at.
Ultimately though nothing beats a decent sampler, so either Structure, Kontakt it Mach5 will fulfill either most of, if not all of your needs.
Reasons cool but having to open 2 apps just to write some music can be a bit painful. Well for me at least.
Old 07-17-2013, 11:28 PM
DAWgEAR's Avatar
DAWgEAR DAWgEAR is offline
Toontrack Superior Drummer 2 or EZ Drummer for drums and UVI Workstation (free) with your choice of synth sample libraries (paid) would be my picks from what is currently AAX 64 bit.
Or buy REAPER (less expensive) or Vienna Ensemble Pro 5 (more expensive) and use your current virtual instruments.
Pro Tools HD Native 2020.11 | HD Omni | iMac Pro 10-Core 3.0 GHZ - 64 GB - 2 TB - Vega 56 | Sonnet Echo Express SE II for PT HD Native PCIe and UAD 2 Quad PCIe card | Avid Dock and S1
Old 07-18-2013, 12:43 AM
Benoni's Avatar
Benoni Benoni is offline
Well if you are talking a real soft synth and not a sample player, then FXpansion Synth Squad should cover alot of ground on the synth side.
For drums, I like BFD2.
Both of these are not currently AAX, so you will have to use them in PT10 until they get ported over.
Something else to look in to would be the AIR Instrument Expansion Pack 2.0.
I also agree with getting Reason 7, that will cover more ground on the synth side and give you a bunch of other effects.
If its a Sample Player you are looking for Native Instruments Kontakt is the standard.
What are you using now for synth and drums? Are you happy with it? That would give us a better idea of what to suggest.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 08-05-2013, 09:10 AM
YYR123's Avatar
I swear I can see the tumbleweed rolling by as the OP has ridden out into the sunset.......Never to be seen or heard from again......
Ok so Im bored at work....guilty as charged.
Daniel
Old 08-05-2013, 07:24 PM
DonaldM's Avatar
DonaldM DonaldM is offline
Don't let your boss see this, then!
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 08-05-2013, 09:28 PM
YYR123's Avatar
On the phone - so he can't see my Internet activity
Daniel
Old 11-04-2015, 08:45 PM
juanmanuel juanmanuel is offline
any drum software download for pro tools 11 in mac?
Old 11-05-2015, 02:31 PM
You have more choices than fingers(probably)
BFD (sounds great, don't have it)
Addictive Drums(sounds great, quite easy to use, works super-easy with E-drums
EZdrummer2(sound great, works great, use it a lot)
SuperiorDrummer2(sounds great, use it a lot, it loads all the EZdrummer kits as well as all the SD2 kits)
Steven Slate Drums(sounds great, never used it)
I know there are other options, but the common thread here is; they pretty much all sound great. Which suits your needs is the tricky part. I would hit each company's website(or youtube) and have a listen.
New instrument plugins for PT11? JCcares Virtual Instruments 7 04-12-2013 04:00 PM
Free Synth/Virtual Instrument Plug-ins like Xpand, Structure Hopeless and Reckless 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-14-2012 07:27 AM
tdm sampler or drum synth? James Drake Pro Tools TDM Systems (Mac) 2 11-29-2011 11:04 AM
Looking for Virtual Instrument / Soft synth demos OC Cool Virtual Instruments 6 12-14-2006 11:10 AM
Soft Sampler/Synth and/or Instrument Advice Chris Coleman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-08-2003 02:55 PM
