Old 05-08-2003, 08:48 PM
clutch clutch is offline
Default Make tracks inactive takes ages
Running a pretty big session - 175+ tracks on an HD3 system. 96 voices over 3 DSP chips. Most of the tracks have been made inactive. System is running OS 9.2.2 PT 5.3.1 on a DP1.25Ghz Quicksilver. 7 Slot Magma chassis. Control 24. sessions are mainly on an internal fast IDE on the fast bus.
It's the same running from our SCSI drives as well.
My problem is when I select only 8 of the active tracks (only 40 or so are not hidden at one time) and make them inactive my system will almost freeze (the only thing that works is the mouse - no clock, nothing else) for up to five minutes before finally making the tracks inactive.
I've got so sick of waiting at times I have force quit the Mac and started again only to encounter the same thing on reboot.
I have also had a few DAE error -1's on boot but a couple of attempts fixes this.
A search on DAE -1 brings up Digi setup things to try - all of which I've done- and Focusrite D3 issues which were fixed with a version change a long time ago.
Any ideas?
He used to cut the grass...he was a very nice boy...
Old 05-08-2003, 08:57 PM
Default Re: Make tracks inactive takes ages
PS this even happens when deleting AUXs with nothing on them!
can my new rocketship be failing so fast!?!
Old 05-12-2003, 07:05 AM
Bump [img]images/icons/confused.gif[/img]
192 analog unit takes ages to turn on stebbingsc4 Pro Tools TDM Systems (Mac) 1 08-01-2011 12:02 AM
Pro Tools MP 9 Takes Ages to load Eddie2468 macOS 11 07-03-2011 05:35 AM
Importing Tracks - Takes AGES JamesH Pro Tools TDM Systems (Mac) 14 02-17-2011 05:48 AM
playback and recording takes ages to start undadogz Pro Tools M-Powered (Win) 2 05-21-2007 12:56 PM
Going into record takes AGES Dan Pinder Pro Tools TDM Systems (Mac) 6 10-23-2005 03:41 PM
