Old 05-31-2001, 05:20 PM
BackToMag BackToMag is offline
Default PT 5.1 Rename Region Bug?
Sorry if this is a duplicate post, I searched but found nothing on this topic yet…
On our G4/* PT5.1 TDM systems we get a system lock-up (complete freeze) if we try to rename stereo regions in STEREO tracks while "Display>Display Auto-Created Regions" is un-checked.
The same files on two Mono tracks (one hard left, the other hard right) have no problems with the rename – regardless of the Display status.
Digi, is this a known bug and if so, is it fixed in 5.1.1?
Thanks.
Old 06-01-2001, 07:51 AM
DigiTechSupt's Avatar
Default Re: PT 5.1 Rename Region Bug?
I could not reprduce this behavior. Steps used:
-Create session (24 bit/44.1kHz)
-Create 3 Stereo Audio Tracks
-Record some audio
-Create some regions
-Disable "Display Auto Created Regions" from the Display menu.
-Double click on the regions visable in the Audio Regions List and rename them.
RESULT:
-No crash.
Couple suggestions:
-Trash the DigiSetup File, Pro Tools preference, and DAE prefs (the entire folder) from the System Folder>Preferences folder. Empty the Trash and restart the Mac. When you go back into Pro Tools, do so from the Pro Tools Application Icon and not by double clicking on a session.
-Rebuild the Desktop file. Hold down the Apple+Option keys while the extensions march across the bottom of the screen during boot-up. Hold the keys down until you get a window prompting you and then Click “OK”.
-Open the Extensions Manager Control Panel. From the selected set pop-up menu, select “OS 9.x base” click on “Duplicate Set" at the bottom of the window. Name the set whatever you like. Enable the following extensions and restart the computer:
-Digidesign Control Panel
-DigiSystem INIT
-Digidesign Direct I/O
-Digidesign DSP Manager
-Digidesign Stream Manager (only if using DirectConnect)
-Open Music System
-USB Floppy Enabler
-Possible corrupt session. Use the File>Import Tracks command to move the tracks into a new session.
-Check the integrity of your drives with Disk Warrior or any other such utility. Repair any and all corrupted catalogs and/or BTree Directories.
Brent
Avid Audio Tech Support
Support FAQ
Old 06-01-2001, 09:17 AM
Brent,
Thank you for the quick reply. We have tried the following on 3 of our G4/Mix workstations. All 3 sys. are brand new, and the result is the same on each.
System Info:
Mac G4/466 384MB RAM MacOS 9.1
Mix Card
PT 5.1 TDM
ATTO SCSI (Digi Kit)
Fuse Card (DV)
Session Info:
16bit, 48K 29.97 Pull Down
Steps:
1. Created new Session.
2. Checked "Display Auto-Created Regions"
3. Added one Stereo track to session.
4. Selected area 8+00 long.
5. Used Sig. Generator to created test tone.
6. Un-check "Display Auto-Created Regions"
7. Make a new region from test tone.
8. Using grabber double click on new region to rename.
9. Cursor freezes immediately – system is completely hung.
Have tried suggestions you listed in last post, but problem still occurs on all 3 machines.
Thanks.
Old 06-01-2001, 10:32 AM
Baixo Baixo is offline
I've had the same results on a G4 4xx AGP (model unknown). Doesn't seem to do it on my own G4 350 AGP.
Old 06-01-2001, 11:58 AM
KingTor KingTor is offline
oh, goodie, I've got another way to make my machine crash if I want it to. Always useful when the client won't give you a chance to walk around and breath some fresh air.
Brent, I think you weren't crashing because you were renaming a region that is displayed in the region list -- double click with the grabber on a region that is an auto-created region and is thus not displayed and it's goodnight ProTools.
Tor Kingdon, Chief Sound Guy
Hear Kitty Studiostwitterfacebook
Old 06-02-2001, 12:07 AM
Thank you King.
You are correct. If you double click on the auto-region - IN the stereo track, you'll get the system hang I was trying to describe in my first post.
If you double-click on anything in the region list, you can rename - no problem.
Digi - if this is found to be a bug, any chance we'll see a fix by 5.1.1?
[This message has been edited by BackToMag (edited June 01, 2001).]
Old 06-04-2001, 05:20 AM
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR><font face="Verdana, Arial" size="2">Originally posted by KingTor:
Brent, I think you weren't crashing because you were renaming a region that is displayed in the region list -- double click with the grabber on a region that is an auto-created region and is thus not displayed and it's goodnight ProTools.</font><HR></BLOCKQUOTE>
-Thanks for the clarification....that was it. I was able to reproduce this on both PT 5.1 and 5.1cs2.
-This is fixed in PT 5.1.1.
Brent
Support FAQ
Rename Region Quick Key Doesn't Work Sometimes? dreamtheater777 macOS 7 09-03-2014 04:11 AM
PT10.3.2 Can't Rename Region little78926 Windows 2 02-13-2013 01:37 PM
Rename Audio Region and File - where go? smc917 macOS 2 09-16-2011 09:54 AM
PT8cs2 - Rename Region Short Key quits working 25ghosts Pro Tools TDM Systems (Mac) 4 04-29-2009 05:03 AM
what good is auto-rename if they don't rename at the root level? graphite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 09-28-2001 01:14 PM
