  #21
Old 10-17-2008, 02:56 PM
carlos santana carlos santana is offline
Default Re: delete rendered files elastic audio BUG!!!
Originally Posted by DigiTechSupt View Post
It seems in the preliminary investigation that these files are being left due to the consolidate process. Consolidating seems to break the link that let's Pro Tools keep track of which rendered files are actually being used and which can be deleted.
while working on another sesion... im having the same issue even though i havent consolidated the audio region (these where imported into protools from a cd-rw wich where edited on another protools system)
  #22
Old 11-18-2008, 06:58 AM
where is our fix!!!!
Pro Tools 7.4cs8 Updates for HD, LE, M-Powered on Mac & Windows
Available from the Pro Tools CS Updates quick link in Support:
www.digidesign.com/support/csupdates
Pro Tools 7.4
  • Pro Tools HD 7.4cs8 for Mac OS X (Tiger)
  • Pro Tools HD 7.4cs8 for Windows XP
  • Pro Tools LE 7.4cs8 for Mac OS X (Tiger)
  • Pro Tools LE 7.4cs8 for Windows XP-Vista
  • Pro Tools M-Powered 7.4cs8 for Mac OS X (Tiger)
  • Pro Tools M-Powered 7.4cs8 for Windows XP-Vista
HD, LE, MP (Mac/Win)
Fixed: Pro Tools and Reason Crash When Loading "Machine" Patches on Reason Adapted Combinator (Item #106627)
* Only occurs in Reason Adapted, and does not occur when Reason Adapted is operated without Pro Tools
HD, LE, MP (Windows only)
Fixed: When Importing More than 100 Audio Files, Pro Tools could Close with no Warning (Item #100595)
* This would occur when importing all of the files at the same time
HD Only (Mac/Win)
Fixed: Focusing A VCA Master on D-Command Causes an Access Violation (Item #105968)
* If trying to save after the Access Violation, the session file could become corrupt
LE Only (Mac/Win)
Fixed: When Recording, Waveform Overviews are Missing or Drawn with Gaps (Item #100862)
* The audio was not affected, and the waveform could be restored by re-calculating it after the record pass
Digi Web Admin
  #23
Old 11-18-2008, 01:29 PM
JGuth JGuth is offline
So wouldn't closing and reopening the session before you consolidate delete the render files??
  #24
Old 11-19-2008, 08:20 AM
NO
please digitech support i think its time to chimme in...
  #25
Old 11-20-2008, 05:47 AM
bump
  #26
Old 11-20-2008, 09:53 AM
DigiTechSupt's Avatar
The fix, obviously, was not implemented in this CS release.
At the moment it's not looking like something that's going to be simple and quick, so it could take awhile.
In the meantime - the easiest way to get around this is to skip that last consolidate, since committing already generates a new audio file. It's the committing that's causing the break which leaves Pro Tools unable to delete the render files.
Avid Audio Tech Support
Support FAQ
  #27
Old 11-20-2008, 10:19 AM
Carl Kolchak Carl Kolchak is offline
Sorry, does that mean it's still liable to be a problem in PT8 when it is released, and does it also mean that even after the release of PT8 it will be addressed in a CS update for PT7.4?
Thanks.
  #28
Old 11-20-2008, 10:28 AM
It's still likely to be in Pro Tools 8 - the mechanism hasn't changed.
I don't have specific info on how it will be addressed yet - we have to have engineering look at it and determine the best course of action.
Support FAQ
  #29
Old 11-21-2008, 11:01 AM
your answer is not specific enough...
i really need a fix (cs) to make my currrent 7.4 system to work as in the manual... if i skip the consolidate i still dont get it to delete de unused files.
will there be a fix for 7.4?
  #30
Old 11-24-2008, 07:02 AM
bump
Missing Rendered Elastic Files Electric Peak Pro Tools 10 10 10-18-2019 10:37 AM
Rendered Elastic Audio files disappearing! huzzam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 02-27-2018 09:50 AM
Have to manually clean up rendered files after committing elastic audio processing jdholman1 Pro Tools 9 1 05-30-2011 12:57 PM
Getting rid of excessive rendered files from elastic operations mixaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-08-2009 01:54 PM
Help me w/ rendered Elastic Audio, pleeze guy.fi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-25-2008 07:03 AM
