Old 04-16-2013, 02:12 AM
Galadriel Galadriel is offline
Default Vox Recording Crashes & Post-Production Sound Quality
I am using Protools 9 with Windows 7. I have all the instruments recorded in wav tracks imported from a Korg, and am using the Protools for the sole purpose of adding vocal tracks, and converting to mp3 in order to upload to YouTube.
I am having two major problems that I cannot seem to get to the bottom of. The first one is that when I am in the process of recording the vocals, as soon as I turn the recording volume up loud enough to pick up my vocals adequately, Protools crashes. I get the message "can't get to the drive fast enough" and the track I am recording in is greyed out. Have to restart all over again. I have calculated that I spend much more time rebooting and trying to adjust the sound then I do recording vocals and naturally it is not optimal to concentrate on vocal recording.
Problem two is that after I finally get the vocal tracks laid down successfully, the final sound quality is fair to lousy. You can hear it for yourself on my Youtube channel in my profile if you want to know what I mean. However: the sound I get on the earphones while in process of recording of both the instrument tracks and vocals is crystal and high quality.
I am not using any plugins, just recording vocals in new tracks straight ahead with a little reverb. Thanks for your help.
D.S., Songwriter & Recording Artist
Old 04-16-2013, 12:16 PM
Craig F Craig F is offline
Default Re: Vox Recording Crashes & Post-Production Sound Quality
please start with Help us Help You - READ THIS Before Posting! at the top of the page
primarily the Sandra report
Thank you,
Craig
Old 04-16-2013, 08:24 PM
zedhed's Avatar
zedhed zedhed is offline
Follow Craig's advice, it's important to know what computer components you're using so Post a Sandra Report.
First thing to ask though is; Are you recording to a separate drive?
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 2024.6 Avid Omni/2 x Fractal AxeFxIII
HD96 I/O
Adam A8H Monitors + A12 Sub
Old 04-17-2013, 01:44 AM
Thank you but I need to establish whether or not I am making basic errors in my input level first while recording.
I am not bouncing to a separate drive. If I do, would that be a CD, or a mass storage I'd want to bounce to? Since PT is in the CD-Rom drive not sure about that one.
I'm looking for guidance from a user who has some experience recording their own vocals and who understands my instinct to turn up the mic input and get an "intimate performance" - someone who might be able to tell me if that instinct is wrong. I suspect it may be a typical mistake that inexperienced performers make recording their own vocals and that maybe I should be turning the input on the mic down. That would not only prevent crashes but also probably create less noise. What I really want to know is whether I can trust that a lower level of input is really sufficient to capture the vocals properly without losing that human touch. Possibly, I am letting through roo much noise that isn't manifesting itself until processing to mp3. Maybe someone can tell me this, how high should the wave form be of properly recorded vocals? Less than halfway? All the way to the top? That would help a lot right there. I'd like to establish whether I am going wrong here first, as I suspect, before pursuing other issues and I have read up on some of those, like cables, etc. Thanks.
Old 04-17-2013, 08:05 AM
Adjusting volume is not what is causing the crash. Its very likely that your system(computer) has hardware issues. This is why we need the Sandra report. Recording to the system drive(drive C:) or a partition of it is KNOWN to cause problems. Since you missed that requirement, its reasonable to expect you missed others as well, or maybe you missed required system tweaks(most are actually....required, not optional). Please post a Sandra
Old 04-17-2013, 05:13 PM
The Weed's Avatar
The Weed The Weed is offline
PT is in the CD-ROM Drive?
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 04-18-2013, 09:56 AM
OK thanks this is the Sandra report:
SiSoftware Sandra
ID
Host Name : admin-TOSH
Workgroup : WORKGROUP
Computer
Model : Toshiba Satellite L655 Intel_Mobile
Serial Number : XA07*****
Chassis : Notebook
Mainboard : Toshiba Portable PC
Serial Number : Base Board S************
BIOS : INSYDE 2.20 06/27/2011
Total Memory : 2.93GB DDR3 SO-DIMM
Processors
Processor : Intel(R) Core(TM) i5 CPU M 460 @ 2.53GHz (2C 4T 2.66GHz/2.8GHz, 1.73GHz IMC, 2x 256kB L2, 3MB L3)
Socket/Slot : FC PGA988
Chipset
Memory Controller : Toshiba Core (Arrandale) Mobile DRAM Controller 2x 2.4GHz (4.79GHz), 2x 1.5GB DDR3 SO-DIMM 1GHz 128-bit
Memory Module(s)
Memory Module : Micron 16JSF25664HZ-1G1F1 2GB DDR3 SO-DIMM PC3-8500S DDR3-1066 (7-7-7-20 4-27-8-4)
Memory Module : Samsung M471B2873FHS-CF8 1GB DDR3 SO-DIMM PC3-8500S DDR3-1066 (7-7-7-20 4-27-8-4)
Video System
Monitor/Panel : LGD LP156WH2-TLAA (1600x1200, LG Display
, 15.3")
Video Adapter : ATI Mobility Radeon HD 5650 (400SP SM5.0 450MHz/550MHz, 1GB DDR3 1.6GHz 128-bit, PCIe 2.00 x16)
Graphics Processor
Compute Shader Processor : ATI Mobility Radeon HD 5650 (400SP 450MHz/550MHz, 1GB DDR3 1.6GHz 128-bit)
Storage Devices
TOSHIBA MK5065GSX (500.1GB, SATA300, 2.5", 5400rpm, 8MB Cache) : 466GB (C:) (D:)
TSSTcorp CDDVDW TS-L633J (339.7MB, SATA150, DVD+-RW, CD-RW, 2MB Cache) : 324MB (E:)
Logical Storage Devices
WINDOWS (C:) : 233GB (NTFS) @ TOSHIBA MK5065GSX (500.1GB, SATA300, 2.5", 5400rpm, 8MB Cache)
Data (D:) : 233GB (NTFS) @ TOSHIBA MK5065GSX (500.1GB, SATA300, 2.5", 5400rpm, 8MB Cache)
SYSTEM : 400MB (NTFS)
Hard Disk (Q:) : N/A
My Disc (E:) : 324MB (CDFS) @ TSSTcorp CDDVDW TS-L633J (339.7MB, SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : Toshiba HM55 LPC Interface Controller
LPC Legacy Controller 1 : Winbond WPCE775LA
Audio Device : Toshiba P55/PM55/3400 High Definition Audio
Audio Codec : Conexant 5069
Audio Device : Toshiba Redwood HDMI Audio [Radeon HD 5600 Series]
Audio Codec : ATI (AMD) HDMI Audio
Disk Controller : Toshiba P55/PM55/3400 4 port SATA AHCI Controller
USB Controller 1 : Toshiba P55/PM55/3400 USB2 Enhanced Host Controller
USB Controller 2 : Toshiba P55/PM55/3400 USB2 Enhanced Host Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : HP Photosmart C309a series fax (200x200, Colour)
Printer : HP Photosmart C309a series (1200x1200, Colour)
Scanners and Cameras
Scanner : Hewlett-Packard C309a,192.168.100.7 (Scanner, 4800x4800, USB)
Network Services
Wireless Adapter : Broadcom 802.11n Network Adapter (802.11n (HT), AES-CCMP, 72Mbps)
Power Management
Battery No 1 : PA381 47.52Wh/4.40Ah
Operating System
Windows System : Microsoft Windows 7 Home 6.01.7600
Platform Compliance : x64
Windows Experience Index
Current System : 5.5
And to answer the question about PT being in the CD-Rom - yes it is in there, because it won't run unless the disc is in the drive, the hardware is in one port and the Ilok in another port. It's PT9, that's why. There is not physically any way to bounce to anything else (other than internal) besides a mass storage device. Could that really make a big difference? Another thing is that when I'm in process of recording I am saving data to an internal folder - should I save the PT data to an external drive while I am working? Cumbersome, but whatever works at this point.
Old 04-19-2013, 10:58 AM
I appreciate the replies. However I was hoping for some practical advice of some measure that I sure take to address this problem.
I had PT 8 before and I had the same issues with it being difficult for PT to run without crashing when the vocal recording volume was at a level where I felt most comfortable singing. The problem with PT 8 however was that it gave me the "Blue Screen of Death" and eventually my computer crashed and it was unrecoverable - also a Toshiba laptop. I had to buy another laptop. I was assured that with my new laptop and system that PT 9 would be an appropriate fit.
What should I try to do in particular to address the problem?
I had also asked about a recorded vocal track - should the waveform be halfway to the top, 75%, 100%? An answer to that would be greatly appreciated as well. Thank you.
Old 04-19-2013, 01:52 PM
a few questions I'm seeing:
1) 3GB of RAM, 1 1GB stick and 1 2GB stick?
2) where is the audio binge recorded to, all I'm seeing is a 5400RPM system drive w/ backup partition?
Thank you,
Craig
Old 04-19-2013, 05:57 PM
The Weed's Avatar
The size of the waveform is a non-issue. Since that is easily changed, it does not represent the volume level. And having to have the PT CD in the drive for Pro Tools to run is something that should not be necessary.
Cheers,
SonoBus
[IMG] code is Off
Post Production Features (Sound FX Cataloging) synkope76 Post - Surround - Video 1 12-22-2010 05:51 PM
NEW Post-Production Sound Forum!!! sonicefx General Discussion 4 03-12-2007 09:20 AM
Sound Post Production Handbook Idea Kuba Pietrzak Post - Surround - Video 3 10-20-2005 12:41 AM
System crashes during post production (002 rack) dsmuv 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-17-2004 06:53 PM
Need help with post production on a live recording project HMT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-22-2003 09:15 AM
