KEM Flatbed and computer sync
I figured folks on this list could help me with the technical side of setting up a Film/Digital hybrid for editing purposes. I'm no-budget filmmaker who prefers to cut film, but with the rising cost of mag, the uncertain future of mag, and the all digital modern mix environments I would like to slave my computer to run in sync with my KEM. I have a friend in NY who edited a 35mm film on his KEM RS and Pro Tools 5.1 linked via audio card/888/USD. He cliamed when the flatbed reaches 23.5fps that PT will slave in sync with the KEM's picture. I have a KEM RS from 1986 which I'm in the process of setting up to send bi-phase tach pulse via 25 pin connector to my Digidesign USD. I have an older version of Pro Tools with the critical setting "sync to external device", but what I have no knowlege and experience with is older audio cards. I have a G4/533 running OS10.3 and as I mentioned PT v5.1. I need to know what audio card will interface well between the PT version I have and a Digidesign 882 or 888? Can anyone help??? Best, Alain in Portland, Oregon |
Re: KEM Flatbed and computer sync
You said you have a USD. Do you have any other digidesign hardware or computer interface cards and/or cables? Please list what you have. One other issue, assuming you have the hardware you need, is that 5.1 software cannot run on OSX, it is best on OS9.1 or 9.2.
Call me by my real name, "Postman" |
You need something like a BIF from rosendahl. A small box that converts bi-phase to TC. It will generate TC and clock your mix system.
http://www.bonsaidrive.com/bif.html frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Thanks. I'm aware that v5.1 will not run on OSX. I've been operating this application in the Classic environment on a partitioned HD. As for hardware.... KEM counter with bi-phase out (25 pin connector) Digidesign USD I need... 25 pin cable from counter to USD cable from USD to 882 or 888 (what cable I don't know yet) cable from 882/888 to computer card (what card I don't know yet) audio card for interfacing Pro Tools v5.1 with 882/888 Alain |
Frank, I thought this was the job of the USD, no? To convert bi-phase tech into TC for Pro Tools functionality. Alain |
or this from JSK
http://www.jskengineering.com/produc...ges/prod01.htm The USD/SYNC I/O are less that perfect dealing with bi-phase. Wire it up and see if yours works if so great
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Craig,
The JSK 1128B is what I use at "The Dub Stage" to lock my Film Projector and my Pro Tools HD Accel systems together. It works great!
Marti D. Humphrey CAS aka dr.sound www.thedubstage.com IMDB http://www.imdb.com/name/nm0401937/ Like everything in life, there are no guarantees just opportunities. |
Biphase should be able to run Pro Tools through your USD. I have not used biphase but I have heard that it works okay. You will probably need to wire your own cable, or have someone do it, for the biphase into USD. I don't know about the KEM, but you should be able to find the USD pinouts in a manual. You will be able to find all manuals you need at this link. All information I am going to mention is contained in various manuals, including the USD, 888, 882, startup, and user guides. I suggest you dig in and start reading!
You should look for a "mix core" card. It is possible to use an earlier d24 card+farm card combo, but I suggest you try to find a mix core instead. The capabilities of a single core card are limited, used mostly for audio in and out, so if you want to run processing plug ins the processing power can be greatly suplimented with a "mix farm" card, that plugs in another computer slot next to the core card. In that case you need a "tdm cable" to connect the two cards together. Either an 888 or 882 interface will work when plugged into the mix core or d24 card. An interface cable was always shipped with each interface. You should be able to buy either type of cable from digi if you need them. You will also need a standard "mac serial" cable to connect between your USD and the mix core card. I hope this helps you on your way. Because you do not have a number of these items, you may want to consider purchasing an entire used "mix system" from someone. Ebay? If it is a complete working system, all of these components will be ready to go. You can add your USD and mac serial cable to it.
Sync Slave Computer to Protools | blizzard | Pro Tools 9 | 1 | 02-09-2012 02:39 PM |
Sync Pro Tools LE and Logic on the same computer-HELP!!!!!!! | kevaquarian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-27-2008 04:49 PM |
Flatbed and computer sync | Alain73 | Pro Tools TDM Systems (Mac) | 4 | 12-09-2005 09:39 AM |
sync pt6 (osx) to DP on a seperate computer... | El CaCa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-01-2003 05:20 AM |
PT6/HD3 on one computer & Reason OSX or OS9 on another computer...How To Sync??? | SHIRK | Pro Tools TDM Systems (Mac) | 2 | 02-27-2003 03:45 PM |
