Error AE -9178
I try to find why I got an error AAE -9178 Until now, it was working well. I usually use Live, and I wanted to move on ProTools or Cubase. It was a long time I didin't use ProTools first and I was thinking to go for a better version. But from nom I got this error. And it is not encouraging. I saw answer about this in the forum, but I don't have WaveShell. I have a special folder fot my VST. I don't understand anythink. I use a Lenovo on Windows 10 with a focurrite scarlett 2i4 and Native instrument keyboard with Komplete Kontrol (that I haven't already test on Protools). I use the Focusrite driver, But I have also the ASio4All installed. I am not an expert, but it is quite complicated to find any answer, and loose time to ununstall and reinstal software. By the way I have lots of VST and it is not posssible to uninstal all of them, It will take me a week. |
Re: Error AE -9178
It does not matter, PT does not use VST and whatever plugins you wish to use with PT|first you must buy from Avid Marketplace. External installs are not working.
Re: Error AE -9178
Is it enough information?
Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz 2.59 GHz 16,0 Go (15,8 Go utilisable) Système d’exploitation 64 bits, processeur x64 I just note that until some months it was working well |
Re: Error AE -9178
And Windows Family
20H2 |
Re: Error AE -9178
I just update withe the build 21H2, and I've got the same error
Re: Error AE -9178
System Requirements say 21H1 only, but I am not a Widnows guy and cannot help you further. Sorry
Re: Error AE -9178
Have you tried using the ASIO4ALL driver? If not, try starting Pro Tools First and hold down the N key while it is loading. When prompted with the Playback Engine, select the ASIO4ALL driver as your sound device. At that point, you should be able to use the program.
AAE-9178 Error | Patshill | AAX Plug-ins | 0 | 06-04-2018 02:30 AM |
AAE Error -9178 | JimGriffith | Pro Tools 12 | 3 | 12-15-2017 05:50 AM |
Getting AAE error -9178 at startup | lufi | Pro Tools | Intro Discussion | 6 | 09-10-2017 02:18 PM |
AAE Error -9178 | JayRosa | Windows | 1 | 07-29-2017 01:28 PM |
Getting AAE error -9178? Here's what worked for me. | mesaone | Pro Tools 12 | 0 | 12-08-2016 11:52 PM |
