buffer size wont go as low now
I have a Saffire Pro 40 running with pro tools 10 on win7 64 bit sp1.
I use to be able to run my interface at 64 samples all the time no problems at all. now i had to bump it up because i keep getting some cpu error pop up. my computer setup hasnt changed at all and i should be able to keep my low sample rate. any suggestions? |
Re: buffer size wont go as low now
Have you optimized your win 7 before? If not try this
Also if you could give us the info needed to help you as stated in this thread, other people might be able to share more ideas. |
Trying to change my buffer size on delta card and pt wont work | dairyman3833 | Pro Tools 10 | 1 | 10-15-2013 10:28 AM |
6086, buffer underflow, hw buffer size and other errors on i7 | rhythmtechnologies | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 05-30-2009 08:36 AM |
Increase Buffer size/Decrease Buffer size? | kerick | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-28-2006 12:00 AM |
Increase buffer size...decrease buffer size.... | Bodhisan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-08-2005 07:24 PM |
DAE Buffer Size wont change for me. | Schnudda | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 05-02-2003 11:48 AM |
