Old 03-01-2005, 07:39 AM
spong spong is offline
Default how do I find out what chipset I have?
I am still having severe problems with my mbox. I can only think that it must be an incompatible chipset. The intel chipset identifier program does not seem to work on my computer. Any other way of finding out what chip set it is?
If it is an in compatable chip set, is there any chance of it becoming compatable or do I have to get cubase et al to get my mbox running?
All I know is that it is a pentium 4 and is 3.06 ghz. The computer is a Dell inspiron 5150 that I bought in January 2004.
Thanks
cheers
spong
Old 03-01-2005, 07:52 AM
K.B. K.B. is offline
Default Re: how do I find out what chipset I have?
Use BIOS Identifier. You can download it from my server here
It's in German, but it's pretty obvious what it all means
Old 03-01-2005, 08:37 AM
I tried it, but the results flash accross the screen in DOS and disappear. Anyway of slowing this down so I can read it?
thanks
cheers
spong
Old 03-01-2005, 08:48 AM
Odd that. Mine doesn't disappear. Mind you, I now remember other DOS windows closing - XP doesn't like them. Try the 'pause' button.
Or restart in DOS and run it from there? Put it on a floppy first so you can find it.
Also, correct me if I'm wrong someone, but when you start up the PC the relevant info is briefly at the bottom of your screen. You have to hit 'pause' quickly to be able to read it.
Old 03-01-2005, 09:02 AM
madrock madrock is offline
download CPU-Z to determine basic information about your system without having to install any software.
unzip the file and double click cpuz.exe which has the cpu-like icon. once it appears, click the mainboard tab and your chipset will be revealed!
if you require more detailed analysis, download sisoft sandra lite.
Old 03-01-2005, 09:08 AM
Rather cool. But...
It tells me how much memory I have, but not the type.
F this! Take the case off and have a look!
Old 03-01-2005, 09:09 AM
a lot of OEM system manufacturers such as dell and ibm have their own splash screen during the POST sequence so you don't get to see any of the system information during boot. although many systems don't display a message as such, hitting tab usually gets rid of the splash screen and displays POST info...
Old 03-01-2005, 09:16 AM
Rather cool. But...
yeah, i think once you go beyond the third tab it gets a little, well, dicey.
Old 03-02-2005, 10:13 PM
FatBelly FatBelly is offline
www.cpuid.com/pcw.php
PC Wizard 2005, thats all you need.
FatBelly Slim
Oh no, not the sprinklers again.
Old 03-03-2005, 01:52 AM
"Chipset: unspecified"
Intel G33 Chipset & Doogz & Can't Find His Post & Pro Tools Willosy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-30-2007 07:15 PM
How to Find Out What Chipset you have?? Noxious 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-19-2005 10:26 AM
915P chipset versus the 915PM chipset valleyarts 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-28-2005 02:22 AM
875P chipset or 865PE chipset Josh K 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-27-2003 06:21 PM
find firewire drive with oxford chipset earprint Pro Tools TDM Systems (Mac) 2 08-21-2001 03:24 AM
